Old 01-30-2006, 08:23 AM   #1 (permalink)
ice
Nochnoi Dozor
trunk degrease?
i went to an auto cross in my 92 se-r and when i took out my spare i decided to gut out my trunk but its black with grease and i wanna know how i can clean it out with out dumping to much water in there
ice is offline   Reply With Quote
Old 01-30-2006, 01:28 PM   #2 (permalink)
sr20boston
1998ccs of fury
Trader Rating: 16 (100%)
When I cleaned out the trunk of my SE-R I used a Shop Vac, a hose, lots of Simple Green, and a big fat sponge.
I pulled all the carpeting and the spare to make my trunk basically a metal shell. Sprayed the sides and bottom with plenty of Simple Green and scrubbed. When I finished that, I hosed it down. There should also be a grommet under where the spare sits which you can pull out so the water drains. It was still a little dirty in the spare tire well so I washed it again with Simple Green.
At this point, Shop Vac the trunk out to get all the little pools of water (like in the little crevices to the left and right of the tail lights). The final step I took was to use paper towels and dry everything fully as well as remove any lingering dirt. I don't have any pictures, but this process made my trunk SPARKLE.
Getting water in your trunk under these conditions isn't a big deal. I had no problems with water getting anywhere it shouldn't. Just be careful with the hose and you should be fine. If you don't have a Shop Vac, just pull that grommet to drain the water and use a pile of paper towels/cloth towels to wipe up the rest.
Old 01-30-2006, 04:25 PM   #3 (permalink)
ice
Nochnoi Dozor
you think i could use something called purple power? its like a degreaser sort of
Sleeper: Its what made the Trojan Horse so popular back in the day.
92 Se-r
Old 01-30-2006, 04:31 PM   #4 (permalink)
scortch99th
Technician @ Toyota
scortch99th's Avatar
same thing , it all works the same just smells different , trust me ..... just let it sit for a few minutes and start scrubing.
91 classic SE-R
94 classic LE
91 240sx(rps13)
COMPRESSED CLIQ
Originally Posted by STRATTON
freddie your a SICK man.
stratton.
Originally Posted by chriscar
Maximum horsepower is dictated by your wallet.
Old 01-30-2006, 07:27 PM   #5 (permalink)
chriscar
merely a flesh wound
chriscar's Avatar
Trader Rating: 97 (100%)
Popping out the big rubber plug is a must! Also, I'll second what Matt said about getting the water out of the wells on the sides. You may not be able to get it all out with a wet dry vac though. If you have an air compressor, then blow it out.
Old 02-01-2006, 10:46 AM   #6 (permalink)
ice
Nochnoi Dozor
just finished, good news: i got all the water out with paper towels (wasnt as hard as i though itd be) and its surprisingly clean.
Bad news: i guess the previous owner painted the well and paint was coming off and i saw alot of rust spots and some were really bad
Old 02-01-2006, 11:07 AM   #7 (permalink)
sr20boston
1998ccs of fury
Wow! That sucks. I hope it wasn't done on purpose to rip you off.
Old 02-01-2006, 12:02 PM   #8 (permalink)
ice
Nochnoi Dozor
i hope not either but i cant think of anything else...gotta start looking for ways to slow down its inevitable death
Old 02-01-2006, 01:24 PM   #9 (permalink)
Rockwood
70/30 Racing
Rockwood's Avatar
Purple power is a little strong and leaves white residue behind. It also etches aluminum.
Steve Rockwood
92 G20 - PTD #73
