Old 01-30-2006, 08:44 PM   #1 (permalink)
fastcoasty
NX Nutcase
SR20 Hoist Tool
Old sr20 valve cover.......$0
Intake mount Engine lift bracket for V8.........$15.95
Not having to deal with a @#$%*$#@%* chain that @#$*%#$*@# slips and no place to hook it to............PRICELESS!!!!!
Just clean up an old valve cover, drill 4 holes for the bracket, and remove the baffles on the underside to put bolts through. Hole to rear of engine lifts eng/trany flat, hole in center lifts eng flat, hole to front of eng lifts trany down for easier in and out.
For those of us who must make due with a hoist.
If I duz it, I ***** get a wipp'n.......Ok, I duz it!
fastcoasty is offline   Reply With Quote
Old 01-30-2006, 08:49 PM   #2 (permalink)
99srnissan
Nice idea, I might just borrow it
1992 Pontiac Firebird
1999 Nissan Frontier
1999 Chevy 2500 silverado
http://www.cardomain.com/id/unclebenz
99srnissan is offline   Reply With Quote
Old 01-30-2006, 08:58 PM   #3 (permalink)
eric96ser I am a moderator
eric96ser's Avatar
Trader Rating: 15 (100%)
I would rather trust 2 bolts screwed into the head than the small valve cover bolts.
1991 Sentra SE-R
The community is here.
Old 01-30-2006, 09:18 PM   #4 (permalink)
fastcoasty
NX Nutcase
A chain is only as strong as its weakest link, in this case it is as strong as the smallest diameter of any single link. Just four of the little valve cover bolts are stonger than any engine lifting chain. Just four little 5/16" carb mount bolts are used to lift big block V8's with these tools every day. I have lifted several engines(sr's) with only 4 bolts without a problem, but it would be best to use them all. With all nuts on and the load spread out all around, this is very strong.
In a day or two I'll put this on my wrecked NX2000 to pull the motor. I will pick the whole front of the car off the ground with it and get a picture to post here.
But hey, in the end you gotta go with what makes you happy, right?
P.S. here's a couple of shots of the swaps I used to do, thats a 1790 cubic inch air-cooled 1100hp v12 diesel engine....and thats a guy reaching under all 18,700lbs. of it as it hangs from some cables.....and they say I'm crazy.
Old 01-31-2006, 01:38 PM   #5 (permalink)
jeffg
No that is a hell of a swap.
Cool idea, now to find an old SR20 valve cover.
jeffg is offline   Reply With Quote
Old 01-31-2006, 04:08 PM   #6 (permalink)
trinispeed
Trader Rating: 17 (100%)
yeah i got one, i will give it to you, i live in canada though
trini
Car shopping made easy! We do the work for you while you save time, money, and hassles! Visit us at Personal auto brokers.com
Karting Vist............www.Torontokartstands.com
trinispeed is offline   Reply With Quote
Old 01-31-2006, 04:13 PM   #7 (permalink)
Yahnozha
Metal Cutting Madman
Trader Rating: 47 (100%)
Its not the size of the bolts holding it onto the VC that Im worried about, its the VC failing under a load that its not designed to take. We dont have nice cast steel/alunimum valley intakes with 12 or so 7/16 bolts holding it on like V8's do.
The VC to head attachments are just little tabs of cast aluminium....thats what I would be concerned with.
But, hey, it worked for you
Old 01-31-2006, 04:36 PM   #8 (permalink)
eric96ser's Avatar
That's what I was getting at, but I don't work with metal everyday. I'm glad it worked for him, but I'm not so sure about trying it.
Old 02-01-2006, 01:31 PM   #9 (permalink)
Rockwood
70/30 Racing
Rockwood's Avatar
I usually use 2 12mm bolts screwed into either side of the head. One on the front above where the alternator is. The other on the opposite side between the distributor and the TB. Just make sure they thread in far. Bolting into the side of the head means you're using 1/2-1" worth of well cast Al surrounded by a lot more Al.
The VC is a weakly cast chunk of Al with a fair amount of porosity. I would say the weak link is where the 4 bolts go through the VC. I would put some really wide washers on there. I would say that Al VC isn't much stronger than a plastic one. It's only meant to look cool and hold oil in. Plus, you can break VC bolts with only 20lb-ft of force. While they probably have a decent amount of shear strength, it's nowhere near what a good chain is rated for, especially the threads in the Al.
Use a load leveler, it's way better. You can pick the tranny up and put it in at the same time. Less work.
Steve Rockwood
92 G20 - PTD #73
Rockwood is online now   Reply With Quote
Old 02-01-2006, 01:33 PM   #10 (permalink)
Rockwood
70/30 Racing
Rockwood's Avatar
BTW: that's a hell of a lot of RTV.
Old 02-01-2006, 05:04 PM   #11 (permalink)
SeRboostSr20
GTI-R DONE
i think there is enough bolts on the head holding down the valve cover to support the weight of the motor, but i still think i would only use it to pull the stock de, seein as there junk anyway, Still HELL AWESOME IDEA
94 Aztec Red Sentra
Gtir Motor Swap with S3M Cams Love Fab Turbo Manifold
and a 3in turbo back.
Turbonetics 60-1 With a PWR Water to Air Intercooler
JWT Ecu 72lb program with Z32 MAF
Running a P11 Tranny with LSD and a JGY locking Insert
All Rolling on Drag DR20s and Ksports.
Best time of 2006 12.4 @ 111mph with a 1.87 60' only running 14psi
SeRboostSr20 is offline   Reply With Quote
Old 02-01-2006, 06:24 PM   #12 (permalink)
fastcoasty
NX Nutcase
Actually, for my next prototype, I plan to make two large single hole brackets from 1/2" aluminum plate and weld one to either end of the valve cover, about as far apart as the chains will be on the engine leveler I plan to order tommorrow.
Old 02-01-2006, 06:27 PM   #13 (permalink)
fastcoasty
NX Nutcase
Did you mean around the valve cover? The old one was glued on with about two whole tubes of the orange junk, and painted a horrible red while still on the motor.
Old 02-01-2006, 06:30 PM   #14 (permalink)
Rockwood
70/30 Racing
Rockwood's Avatar
Gross.
Like I said, I would try to spread the load out on the VC because it's a really sh*tty cast for strength.
Old 02-01-2006, 08:17 PM   #15 (permalink)
rage
SR's are a fad
bingo
rage is offline   Reply With Quote
Old 02-01-2006, 08:31 PM   #16 (permalink)
eric96ser's Avatar
It's a good idea, until the valve cover, or the bolts fail, and the engine that is a few feet off the ground, falls on the car, or you. I'd much prefer to do it the hard way, and use the 2 bolts in the head, and drop the motor, insead of puling it. That's just me though.
Old 02-02-2006, 10:40 AM   #17 (permalink)
NX$paniard
easy 400WHP
Trader Rating: 26 (100%)
the valve cover will fail before the bolts do.
I dont see whats so hard about bolting a chain to the head at two adjacent points. Ive done a motor drop and install by myself with no problems at all.
I just would not trust a thin section of sand casted aluminum to support a load like that. It'll probably work a few times, but when it fails it will fail without warning. Dont like the idea of an engine falling on my head.
~jRod
Old 02-02-2006, 11:36 AM   #18 (permalink)
Killdannow
Where are you guys putting two bolts in the head ? Or are you using bolts that are already there?
Clean a$$ hell red 200sx.
Old 02-02-2006, 12:05 PM   #19 (permalink)
La_Noche
the spookman
i just have a chain thats long enough to loop around the exhaust manifold and around the intake runners
05 Legacy GT
93 NX2000 w/VE
(\__/)
(O.o )
Old 02-02-2006, 01:07 PM   #20 (permalink)
NX$paniard
easy 400WHP
dude, closely examine the sides of your head. There are tons of bolt holes you can use to bolt the chain up and most, if not all, the thread sizes/pitches are the same.
