Conversion table for bigger rims/tires - SR20 Forum
Old 03-29-2007, 11:51 AM   #1 (permalink)
"The Chubby Panda"
Feedback Score: 21 reviews
ba ha ha ha]
My other NX....is an NX.
Canx2k is offline   Reply With Quote
Old 03-29-2007, 12:01 PM   #2 (permalink)
"The Chubby Panda"
Stock rim sizes:
NX 14" rims:
6.0Jx14
40mm
Tires were 195/55-14.
B14:
195/55/15
if anyone would like to add to this or correct me, please do.
another fantastic conversion table can be found on:
http://www.1010tires.com/TireSizeCalculator.asp
Old 03-29-2007, 12:28 PM   #3 (permalink)
merely a flesh wound
chriscar's Avatar
Feedback Score: 110 reviews
Unless someone can prove me wrong, nothing beats Mark Sink's calculator.
http://marksink.com/tire_wheel_offset/tires.html
This is the first time I've looked at it in a while, and it's better than ever.
Old 03-29-2007, 12:40 PM   #4 (permalink)
"The Chubby Panda"
Are all 16" rims able to fit any of the first numbers? According to that table, If I was to go with a tire that is 185-45-r16 or 195-40-r16 or 205-40-r16 I'd be ok. The rims I have right now have 205-45-r16 on them, and I need to know if any of those sizes will still fit the rim.
these are the rims I have:
http://store.summitracing.com/partde...5&autoview=sku
Old 03-29-2007, 12:48 PM   #5 (permalink)
chriscar's Avatar
If you're talking about the link I sent, it doesn't account for rim width. It's really best to use if you're starting with your stock size tires and want to know what fits and keeps you within a specific speedometer error range (in other words, staying as close to stock diameter as possible).
What car do you have, and what's the stock size tire?
Old 03-29-2007, 01:00 PM   #6 (permalink)
"The Chubby Panda"
I have a NX, stock 14" tires. The rims I've got are riaxx seca 16" tires. They have a 7" width according to the website.
Old 03-29-2007, 01:12 PM   #7 (permalink)
chriscar's Avatar
NX's came with 195/55/14's stock. So plug that into the calculator, set the max size to 16" 225mm and 2mph error, and you'll get a bunch of results. Not all of the results are actual sizes that are made though.
A 205/40/16 is the closest match in overall diameter, and there are allot of tires available in that size. You don't want a 185 or 195, it's just too narrow for a 16", and there are only a few made.
As far as what will fit on a 7" rim, a 205 will be fine.
Old 03-29-2007, 01:14 PM   #8 (permalink)
"The Chubby Panda"
sweet. thanks again chris, you once again prove yourself to be the best at this stuff.
the offset on the nx is 40, this rim says +42mm, do i need a spacer at all then?
Old 03-29-2007, 01:18 PM   #9 (permalink)
chriscar's Avatar
Hehe, don't ask me. Offset confuses the hell out of me.
Old 03-29-2007, 01:31 PM   #10 (permalink)
VE 96 SE-R
Feedback Score: 18 reviews
Originally Posted by Canx2k View Post
Stock rim sizes:
NX 14" rims:
6.0Jx14
40mm
B14:
195/55/16
i'm thinking it's just a typo, but the B14 SE-R came with 15" stock wheels.
Robert Sousa
SR20DEEP CA
http://i17.photobucket.com/albums/b5...IMGP5288-2.jpg
96 SE-R VE goodness
95 G20, VE super stock DD
SER96VPEC is offline   Reply With Quote
Old 03-29-2007, 01:50 PM   #11 (permalink)
"The Chubby Panda"
whoops! my bad, edited.
Old 03-29-2007, 02:00 PM   #12 (permalink)
"The Chubby Panda"
anyone?
Old 03-29-2007, 02:52 PM   #13 (permalink)
_______
spnx's Avatar
Feedback Score: 4 reviews
Lower the number = wider the track, because it's positive offset. With a 7" wide wheel, I've found a +35 offset to be perfect for the NX2000.
James
spnx is offline   Reply With Quote
Old 03-29-2007, 03:35 PM   #14 (permalink)
"The Chubby Panda"
edited
Old 03-29-2007, 03:51 PM   #15 (permalink)
"The Chubby Panda"
Ok, so I guess going from 40 to a 42 isn't a big deal from what i've been reading. But I'm a little wary on going to 16" rims which are 1" thicker, bolting them up and getting rubbing. I have stock shocks, so would I need a spacer, or anything of that sort to prevent rubbing?
Old 03-29-2007, 05:37 PM   #16 (permalink)
llaprad1's Avatar
Feedback Score: 12 reviews
http://www.miata.net/garage/tirecalc.html
woot!
Louis - 1993 Nissan Sentra SE-R
Rallycross Machine!
llaprad1 is offline   Reply With Quote
Old 03-29-2007, 06:15 PM   #17 (permalink)
chriscar's Avatar
Originally Posted by llaprad1 View Post
No way, Sink's is way better.
Old 03-30-2007, 06:17 PM   #18 (permalink)
Is an SE-R/VE a VE-R?
Coolness. When I did my tire fitting I just dialed in Google and looked at what popped up (1010, Tirerack, miata). I like the Sink page, Chris. Thanx.
Jer
'93 B13, etc.
do it over and over again?
Old 03-31-2007, 09:53 PM   #19 (permalink)
Hostile Aberration
Shawn B's Avatar
Feedback Score: 10 reviews
You have been assimilated.
http://www.sr20forum.com/driveline-transmission/170794-b13-b14-b15-suspension-information.html
See "A Few Words About Wheels and Tires."
Great thread, excellent information.
