Cheap Bastard
UPDATE: 3/31/08
May be selling the B13 soon.....losing interest, and I'll probably just keep the Mustang for now.
So the track slut will be for sale soon!
1994 B13 SE-R
-SR20 RR w/ S3R cams, Hotshot Gen 5, custom 3" exhaust from the collector all the way back to the rear bumper, JWT ECU mounted in a waterproof Pelican case in thepassenger footwell, AEM CAI, ES mounts, Clutchmasters lightweight flywheel & pp (zing!), A/C delete, UR crank and W/P pulleys
-6 point 1 5/8" DOM cage, gusseted, and tucked out of the way, Prodrive WRC by Sparco (split thigh bolsters like a Cobra Suzuka) seat with custom 6061 aluminum side mounts on a rigid mount, new Sparco 5 point harness (needs the lap belts and crotch belt to be installed), Odyssey 680 mounted in trunk with 2/0 fine strand cable to the engine, push off/twist on kill switch mounted on the center console, dash in great shape and fitted around cage, signals, power mirrors and speedo/tach all operating, center console still intact, new front windshield (crystal clear), side windows still operate, door panels and rest of interior removed, painted white inside, convex rear view mirror mounted on cage, gas door release still operable, quick release Sparco suede wheel, sound deadening removed,
-Fastbrakes 11" front with Willwood dynalites, 2 (two) sets of Rota Grids: one with Azenis & one set with Used RA1s, custom 10mm spacers with hubcentric lips for Honda centerbore, NISMO long studs, Trust aluminum lugs, braided front lines, Hyperco Gen 2's (first GB!), KYP AGX's, Progress rear sway, stock front sway
-Carbon hood & trunk, Aerocatches mounted on both front and rear carbon pieces, fresh black paint in 2006, Stillen front air dam one quick release Dzus fasteners for quick trailer tiedowns and loading, all undercaot removed from wheelwells and painted black
-Spares: KYB AGX, original SR20DE with sl. rod knock, MAFs, ECU's, Cobalt pads for Dynalites, fuel pump, originial fogs, ign. coil, filters, straight pipe to remove muffler (3 bolts), S5 Cams for SR20DE, etc....
$4500 takes it all!!! Perfect HPDE car, minor prep wil make it nice NASA car, has run in a few TCRA Time Trials. Will not part out. I'll be back at home at the end of April, so serious buyers can have a chance to look at it.
