Old 09-14-2007, 06:04 PM   #1 (permalink)
chronic_werewol
Big Dreams, Small Budget
Emissions, EGR removal?
I have a friend who flips two-fowdies (240sx for the rest of y'all), and has been around KA's for quite some time, and occasionally, the SR. He suggested I remove the oil catch reservoir that sits in front of my motor, mounted just below the valve cover (two little black metal boxes with a few tubes coming out, and a vacuum actuator), and plug the EGR. I've taken some time to inspect where these hoses go, and for the most part, it looks like a complicated PCV system. The EGR just circles back around to the intake. I know that it's mostly for emissions, but also for fuel/air mixture proportioning, in a small way. He told me he's done it to some of his cars in the past, and they pass emissions and run better. It would get rid of much of the tubing and crap that I have to remove every time I remove the valve cover.
1. Should I attempt this at all?
2. Any good pointers, if yes?
3. Will my car run better?
4. Will it pass emissions?
1991 B13 SE-R JDM SR20
The little red bastard - handling and traction 1st, speed 2nd.
The good drivers are the ones that understand they may not be the best out there, but know what to do to get there.
chronic_werewol is offline   Reply With Quote
Old 09-14-2007, 06:21 PM   #2 (permalink)
kingofrock381
moe.ron
I'll be nice and anwser your question, usually people wont anwser this becasue it can be anwsered by searching. But when i was new to the SR20 scene and cars in general i asked the same question.
1. yes, it cleans the engine bay up allot, the EGR system gets cloged and causes a number of prolbems. my car runs better becsue i took it all off, BUT leave the oil catch can on, its there for a reason, your friend saying to take it off just shows that he talks out of his ass possibly, so dont take to heart every thing he says
2. just take your time, makes some nice block off plates and seal them with some gasket maker, or you can buy a set from some where, search for it its around here some where.....make sure you hook up or block off any vaccume lines you mess with.
3. Possibly, my car did but my car has 207,000 miles on the orginal engine. Also check your ACC valve, clean it, and put it back on, put a new PCV valve on, and do the noram full tune up.
4. probly not, im unsure, West Vrigina doent even check, so maby some one else will post up.
for some more inspiration check out my se-r, look in my recent posts
1991 SE-R basic N/A bolt-ons
left to waste away, but REBORN, died, reborn, bashed, then reborn, the nit died again, revived it, gone through 5 alternators in 2 years, but its running strong again, now i just need some AGX's and some magnets and a DET swap
kingofrock381 is offline   Reply With Quote
Old 09-14-2007, 06:34 PM   #3 (permalink)
gtlaw
SE-R Newbie 4-life
1 if its not causing any problems no. I only removed the stuff because I installed a header and the fittings for were completly rusted
2 your going to need threaded plugs for your exhaust manifold, and block off plates for the intake. have fun with the vacuum lines
3 mine didn't it just weighed a few pounds less, and has a cleaner engine bay
4 I passed PA emmissions with egr and aiv removed the guy had to run it two times though.
gtlaw is offline   Reply With Quote
Old 09-30-2007, 07:17 PM   #4 (permalink)
chronic_werewol
Thanks guys, I appreciate it. I also know of people cutting the EGR tube, crimping what's left and welding it shut on the manifold, which I might likely do.
Old 09-30-2007, 11:13 PM   #5 (permalink)
johnnym
Live Fast. Die Faster.
Get the nissport egr removal kit. I ordered mine and couldnt be happier.
Long Way Down.
johnnym is offline   Reply With Quote
Old 11-15-2007, 03:44 AM   #6 (permalink)
SERLKLR
just pay the guy 20 bucks and put your mom's minivan on the dynomometer. Yay for OBD1
SERLKLR is offline   Reply With Quote
Old 03-28-2008, 02:36 PM   #7 (permalink)
SwaN
anyone direct me to a vacuum line re route link?
or a good write up, been searchin and reading for hours!
thanx!
85 NiSwaN 720 Longbed...z24, 5speed
91 NiSwaN Sentra Se-R...sr20de, 5speed
"Drive it like you stole it!"
"The deciding factor lies beneath the hood!"
SwaN is offline   Reply With Quote
