Old 05-01-2008, 11:35 PM   #1 (permalink)
twistedmindz
The champ is here
Trader Rating: 4 (83%)
best way to remove
hey forum so i got oil on my concrete which was just redone wats the best way to remove the stain?
Buy Build Blow up Start all over again
twistedmindz is offline   Reply With Quote
Old 05-02-2008, 02:38 AM   #2 (permalink)
ser20
uh.....ok!
cat litter to soak it up. or go to checker and get the stuff in the bag for soaking up oil. or just use saw dust. then a lot of simple green or other degreaser...
98 sr20: prothane mounts,p.o.s. catback exhaust, stillen 9lb flywheel,p.o.s. xtd clutch. NOTHIN to brag about!
ser20 is offline   Reply With Quote
Old 05-02-2008, 03:37 PM   #3 (permalink)
narcotix
Cheap Bastard
narcotix's Avatar
Brake cleaner, then soak it up with any absorbent of your choice...kitty litter, oil sweep, sawdust, etc. Repeat until gone or almost gone. Follow up with some simple green, or Tide and scrub or pressure wash.
"Better living through chemistry...."
narcotix is offline   Reply With Quote
Old 05-02-2008, 09:52 PM   #4 (permalink)
Yosho
Kitty Litter and a brick... lay down the kitty litter to soak up any easy to get oil, then after you clean that up take some new kitty litter and gently grind it against the concrete with a brick. It should pick up much of what's left.
- Yosho
'96 Nissan 200SX SE-R
'04 Mazdaspeed Miata
'04 Volkswagen R32
Yosho is offline   Reply With Quote
