Old 05-04-2008, 03:54 PM   #1 (permalink)
prodrifter
Free Hugs
Painting over powdercoat?
Hey all, I want to paint my AEM cold air intake black and it's currently powdercoated silver from the factory. Is it ok if I sand the powdercoat, prime, and paint it? Or does it need to be blasted and powdercoated again?
Thanks
The Ride: 1993 Nissan Sentra SE-R
~knuckleduster~'s weekend warrior car. Now daily driven and tracked.
prodrifter is offline   Reply With Quote
Old 05-04-2008, 04:08 PM   #2 (permalink)
projectmk3
"Boost Before Looks"
Trader Rating: 15 (100%)
depends what kind of quality you want...i personlly wouldn't really care how or what color it would be ... if i was to be painting it i would prolly:
sand at least with some steal wool pad
spray primer
high heat paint (best if used light coats...you will find yourself doing a lot of layers but in the end it is better)
and your done ...let it dry well
7)1991 Se-R -Current
6)1994 Sentra -Sold
5)1992 Acura Integra Gs-R -Sold
4)1990 Acura Integra -Sold
3)1993 sentra L.E. -traded
2)1993 Bmw 325is - crashed
1)1994 sentre L.E.-traded
projectmk3 is offline   Reply With Quote
Old 05-07-2008, 02:19 PM   #3 (permalink)
wnwright
Boost Addict Anon Member
Rough up and paint on the powder is good.
Powder coating makes a good base coat.
2k1 Sentra SE "Stock"
wnwright is offline   Reply With Quote
Old 05-08-2008, 01:45 PM   #4 (permalink)
prodrifter
Free Hugs
Sounds good. Should I even bother with using primer or should I still do so?
Old 05-09-2008, 01:37 AM   #5 (permalink)
tamas
hey there
as long as the powdercoating is not shiny or glossy anymore you can just paint rite onto it, at times old paint without clearcoat is a better base coat then primer.
tamas is offline   Reply With Quote
