Old 05-23-2005, 03:32 PM   #1 (permalink)
broke, busted and rusted
degreasing entire engine
I finally got around to replacing my vavle cover gaskets thank you very much for all of the help from the forum once again!
Now I have another issue I want to take care of. Because my VC gasket was leaking BADLY for so long, my entire engine/engine bay is filthy, like really filthy.
Any tips on detailing an engine bay? I did read the article on se-r .net but was missing info like what all needs to be wrapped up bsides the MAF and the distributor?
I have never done this before and Im not trying to damage anything. water and electricy dont really mix to well.
good news: under my valve cover was surprisingly clean. Only one tiny deposit of black stuff near the timing chain guide everything else was clean and clear, not bad for 130K on the clock.
Fonque is offline   Reply With Quote
Old 05-23-2005, 03:39 PM   #2 (permalink)
i love b13's !
Trader Rating: 22 (100%)
yeah wrap up the maf and the cap and rotor. get a crap load of cans of break cleaner and simple green. spray the engine with the break cleaner and scrub with a wire brush for the engine and use a plastic brush for other parts. then was with simple green let it sit for a few minutes. rinse if off let it dry. and repeat till you happy.
im back.......
Old 05-23-2005, 03:41 PM   #3 (permalink)
simple green and brake cleaner wont damage the paint in the engine bay?
its not like I care since my engine bay is red and my car is black.
Old 05-23-2005, 03:43 PM   #4 (permalink)
Drinking The H Juice Now
BigB's Avatar
I used Gunk Citrus engine cleaner the other day.. worked awesome! got it at NAPA
1992 SE-R WHT - SOLD
1992 SE-R BLK - R.I.P.
1999 Integra GS
1991 Integra LS -
BigB is offline   Reply With Quote
Old 05-23-2005, 03:44 PM   #5 (permalink)
i love b13's !
ive used brake cleaner on the engine block valve cover. i havent used it on the engine bay its self. that i wouldnt know but i have seen brake cleaner eat paint up so id say avoid getting it on paint. the simple green sh*t is a concentrate, so you mix it with water. toss it on scrub everything up. let it sit for a few minutes and spray it off. ive never had a problem using simple green.
Old 05-23-2005, 03:49 PM   #6 (permalink)
cool, I havent been able to find a place to buy simple green I have been using Gunk Citrus which work ok.
btw, Mooninites kick ass!
Old 05-23-2005, 04:36 PM   #7 (permalink)
I used the foaming Engine Brite and it worked well.
"I hope you can see this, Cause I am doing it as hard as I can - ignot"
Davis
'96 200sx: HS CAI, HS Header, 2.5" VRS Exhaust, Timing 17*, Hyperco's/AGX's, ACT HD w/ Street Disc, 8lbs ADFab Flywheel, Prothanes, B&M SS, '98 Honeycomb Grill, G20 ECU, '92 Intake Cam. B-13 Front Seats, Ground Kit by ToolAPCfan.
Awaiting Install:Outlaw Thermoblok Spacers.
ShockerMods
thrive_808 is offline   Reply With Quote
Old 05-23-2005, 05:19 PM   #8 (permalink)
Registered User
After you degrease the sh*t out of it, spray some foaming tire shine on everything. This will make it look purdy.
-Tim
sr20ser is offline   Reply With Quote
Old 05-23-2005, 05:31 PM   #9 (permalink)
B13 Newbie
Can you spray into the engine bay with the hose, or do you have to mist it and wipe it up? Like how much pressure?
'03 Spec-Vagina (white) - I/H/E/P/GK/MM/SS
[Injen/Hotshot/Stromung/SWA/Grounding-Kit/ES/Faktion]
'91 B13 SE-R (white) - I/E/MM/RSTB/FSTB/SUSPENSION
[K&N/2.25"/Prothane/ActiveTuning/eBay/AGX/HyperCo/Whiteline Brace]
Picture of Both: http://img101.imageshack.us/img101/5254/b15b13ni0.jpg
sgtiger is offline   Reply With Quote
Old 05-23-2005, 08:49 PM   #10 (permalink)
just a G thang
honestly all you need is a bottle of simple green.....that stuff freakin cleans anything if you ask me.....i just spray and then let it sit for about 10 minutes then wash the whole engine bay down and then use armoral wipes to make everything shinny....
vince
G20/Primera
D2 damper kit, hotshot cold air intake, topspeed header, nismo radiator cap, front superpro bushings, octocat rear strut bar, obx b10 axle back exhaust, Apexi SAFC-ll, P11 mesh rims, Primera phase 1 grille, Primera amber corners, NGK iridium plugs, 300zx tt fuel filter, Primera sidemakers and striped interior
GUAM'S G20 is offline   Reply With Quote
Old 05-23-2005, 09:59 PM   #11 (permalink)
Castrol super clean degreaser. Run the engine for a few minutes to make the grime easier to remove. As said earlier, cover the MAF and the cap & rotor. Also lay a bag/towel in the spark plug portion of the head, around the wires. If you get water in there, chances are it will get in the spark plug holes, and when the engine gets to operating temp, the water will boil and the car will miss like crazy.
Infiniti Rydah is offline   Reply With Quote
Old 05-23-2005, 10:37 PM   #12 (permalink)
the spookman
Heheh I do this all the time at work. Just coat the engine bay with a simple green like cleaner then hose it down for a minute or so. they come out nice and clean but its something id never do to my own engine.
05 Legacy GT
93 NX2000 w/VE
(\__/)
(O.o )
Old 05-24-2005, 01:09 AM   #13 (permalink)
B13 Newbie
I just found an awesome thread on a BMW site regarding this:
http://forum.e46fanatics.com/showthread.php?t=7086
Lots of before/after photos in there. Basically the consensus was to use this method:
I recently attended a detailing seminar hosted buy a bunch of detailing pros. I couldn't believe some of the tips-n-tricks I learned that day.
I was particularly interested in how they go their engine bays so clean. I just couldn't imagine anyone cleaning every belt and hose with a tooth brush and some Amour-All.
Well, they had a demonstration using a Porsche 944 with an engine bay that had not been cleaned in years. Here's how it went...the ending shocked me.
1. Let the engine run for a minute or two to warm it up. Grease and other gunk is easier to remove when the engine is warm (NOT HOT).
2. Cover any exposed electrical components and anything else you do not want to get a bunch of water on with aluminum foil.
3. Get a can of engine degreaser from your local auto store...they used GUNK Engine Degreaser. Spray it liberally on everything! Don't be shy...they used the entire can. Let is sit for 10-15mins so it can breakdown and loosen all that grime.
4. Get the hose out and spray down everything to remove all the degreaser and dirt and grime. Do not use a nozzle...just the hose is enough pressure. You do not want to blast water into all the engine components...especially on newer cars.
5. Let the water run off for a few mins and start the engine and let is run for 30 seconds to help dry some of the water.
6. Here's the final step that SHOCKED the hell out of me. They sprayed the entire engine bay down with WD-40. They used an entire can and sparyed it on EVERYTHING! After they were done; the engine looked BRAND NEW. I was told this is how many car dealers get the used cars to look brand new under the hood. Some substitute Pledge furniture spray instead of WD-40 (believing WD-40 attracts dust).
I wouldn't believe it unless I saw it with my own eyes. The Porsche engine looked flawless and every hose and belt looked brand new. I'm planning on doing this to my car this weekend.
Old 05-24-2005, 01:18 AM   #14 (permalink)
i love b13's !
^ thats great info right there.
Old 05-24-2005, 01:49 AM   #15 (permalink)
just a G thang
tru
vince
Old 05-24-2005, 03:17 PM   #16 (permalink)
Set Verbose On
Originally Posted by GUAM'S G20
tru
vince
third -- thanks for that link
1991 SE-r Aztec Red "Quiet, She's sleeping"
1992 SE-r Ruby Red "Now with 100% less engine"
1992 SE-r Black Beauty... "It's not his anymore"
Bearjing is offline   Reply With Quote
Old 05-24-2005, 05:13 PM   #17 (permalink)
That's what I said earlier I skip the step at the end when you apply either tire shine/wd-40. It attracts dirt to it, so the motor looks dirtier, faster. I personally just like the look of a clean, grime free engine bay without all the added shine.
Old 05-24-2005, 05:45 PM   #18 (permalink)
Registered User
I only have to spray the engine down about once a month to keep it clean. The tire shine doesnt attract more dirt, and this is a DD (90 miles to & from work).
I would think that spraying the belts with WD-40 would cause them to wear out, and slip..
-Tim
Old 05-24-2005, 05:58 PM   #19 (permalink)
damn thanks for all the info, looks like other people had the same questions. This thread should be saved somewhere for easy access. I am deffinately going to have to try this once the rains go away.
edit: I just read through the entire bmw thread, and the results from some of the pictures are damn amazing!!
question: can you just "HOSE" down the engine or should youjust mist it down?
also what about the battery? couldnt the water short the terminals?
Old 05-24-2005, 10:53 PM   #20 (permalink)
the spookman
as long as electrical/intake is covered up, yes. and im no electrician...but no the water does not short the battery out. i do this all the time at work and have never had a problem. hell i know a place that powerwashes engine bays.
