Maf to MAP - SR20 Forum
post #1 of 31 (permalink) Old 05-31-2005, 02:10 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Maf to MAP
Everyone nows that an SR20DET uses a MAF sensor
i want to know how can i convert my SR20det that is MAF to MAP sensor?
can anyone tell me how?
any links on how to?
any documentation?
thanx
Gargoyle is offline
post #2 of 31 (permalink) Old 05-31-2005, 02:18 PM
I can't find my pants
Quoted: 0 Post(s)
They're the same thing. You just have to make sure you use the ECU for the corresponding part (USDM SR20 MAF - use USDM SR20 ECU)
hosmer is offline
post #3 of 31 (permalink) Old 05-31-2005, 02:23 PM
Quoted: 0 Post(s)
Feedback Score: 4 reviews
MAF= Mass Air Flow
MAP= Manifold Absolute Pressure aka speed density.
The only way I'm aware of is running a standalone. I think I remember reading that the Emanage can also do it, but I'm not sure.
mpg9999 is offline
post #4 of 31 (permalink) Old 05-31-2005, 02:31 PM
Grandma's gonna get ya!
coalitionSE-L's Avatar
Quoted: 0 Post(s)
Feedback Score: 6 reviews
any documentation?
thanx
Run a standalone. A few of us are discussing how to convert the stock ecu using editing software but this is quite a complex process that probably won't be figured out very soon.
1999 SE-L SR20DET-- Sold!
coalitionSE-L is offline
post #5 of 31 (permalink) Old 05-31-2005, 02:31 PM
NA bliss.
Quoted: 0 Post(s)
^^ Tomei did that. They sell their ECUs for a hogillian dollars.
Find a MAP sensor, hook it up to the car. Get the values at certain points that your car puts out on the MAP sensor and the MAF. Make some resistor pack to change the values in line to the ECU. Do-able. HOWEVER, it will only be good for a certain barometric levels and air temps. With big changes in either you would have to change the resistor pack around. You could set up an intake air temp sensor and have that edit information sent from the MAP to the ECU. Probably a lot more work that it is worth.
I would say go with like a megasquirt but then you have to ditch the Direct Ignition and get a dizzy and ign wires. Then you could set that up to run on a MAP sensor.
If you have more money and don't want to mess with a dizzy, AEM ems.
If you are made of money and want me to tune it for you get the Tomei ECU. It is pretty!
SR20DE S13 280zx front end
Drift Assoc. LLC - Chief of Tech, tech questions? Richard Maertz
LOVEMUFFIN is offline
post #6 of 31 (permalink) Old 05-31-2005, 02:32 PM
Quoted: 0 Post(s)
MAFs and MAPs are very different.
post #7 of 31 (permalink) Old 05-31-2005, 02:33 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
they are no the same!!!
MAF = Mass Air Flow
Definition: is a way to measure the amount of air an engine takes in (engine load). This sensor not only measures the volume of air but also compensates for its density as well.
MAP = manifold absolute pressure
Definition: Refers to a manifold absolute pressure sensor, a variable resistor used to monitor the difference in pressure between the intake manifold at outside atmosphere.
what i want is to convert my sr20 fromo maf to map
thanx again
Gargoyle is offline
post #8 of 31 (permalink) Old 05-31-2005, 02:36 PM
Quoted: 0 Post(s)
You couldn't just "hook up" a MAP sensor. You wouldn't need to anyway, their voltage response is linear unlike MAF sensors. The math for MAP sensor response is simple. Making the conversion requires altering the factory ECU's VQ map as well as the load axes of every other map.
post #9 of 31 (permalink) Old 05-31-2005, 04:57 PM
Quoted: 0 Post(s)
what would the benefits be by switching?
www.SE-R.net
'07 Sunlight Silver Mazdaspeed3: 263hp, 280lb-ft torque, Injen Intake, HKS SSQV BOV: My Ride
'06 Silver Altima SE-R: the Wife's ride
'94 Black Infiniti G20t: the Spare ride
SOLD '92 Black Sentra SE-R: 9.20 @ 74.xx mph, 1.98 60ft. 1/8th mile N/A
8.239/8.243 @ 82.xx mph, 1.784/1.726 60ft. 1/8th mile w/ Nitrous
SOLD '91 Red Sentra SE-R: the former Daily Beater
REDLINEse-r is offline
post #10 of 31 (permalink) Old 05-31-2005, 05:19 PM
NA bliss.
Quoted: 0 Post(s)
So your telling me you can't hook a MAP sensor up to a car 12v-GND-VAC... like I did mine.
Then run the car... like I did mine.
And get voltage readings from the MAP sensor... like I did mine.
Well f-ck, someone call the reality police 'cause I am breaking their laws.
No, it does not require and ROM tuning. You can force the car to run on a base map and change that using input from the MAP sensor. I am not saying anyone can do it. But with enough electronics knowlege it can easily be done. By the time you are done you will have fine tuned a very sell-able product too. How the hell do you think Apex came up with the S-AFC, some car god gave them magic in a plastic box. That kind of stuff is not magic and you don't need a fancy display to make it work. I believe there is a guy in Austrailia working on this very thing right now.
post #11 of 31 (permalink) Old 05-31-2005, 05:24 PM
banned
Quoted: 0 Post(s)
Feedback Score: 44 reviews
any documentation?
thanx
Why exactly do you want to do it, you seem like you dont know what your talking about and it seems like you only want to do because " everyone" is doing it. A z32 maf is more than enough or even a blow-through setup will get the job done. With maps its easier to tune, but that doesnt mean its impossible to tune on a maf
B14 Se-Rious is offline
post #12 of 31 (permalink) Old 05-31-2005, 05:41 PM
Fuck you.
Quoted: 0 Post(s)
Feedback Score: 16 reviews
So you installed a MAP sensor, removed the MAF, and didn't touch the ECU. Please by all means tell us how.
Setzer is offline
post #13 of 31 (permalink) Old 05-31-2005, 06:16 PM
NA bliss.
Quoted: 0 Post(s)
Jeebus christ no! I just hooked the MAP up to see what the peak reading and the base reading was and a few points in between. I did not use it to run my car. I never said I used it in place of the MAF, just used it to get some starting data so I know what range to include in my fuel map.
post #14 of 31 (permalink) Old 05-31-2005, 06:20 PM
smoke and a Pancake
Quoted: 0 Post(s)
any documentation?
thanx
your weird...?
I my Nissan
WHITE 96 200sx se-R
shift_..
__________________________________________________ __
USPS classifies Guam with the rest of the USA as far as shipping rates go...
Check UPS and see if they have USPS rates. Thank you.
nomad is offline
post #15 of 31 (permalink) Old 05-31-2005, 06:22 PM
se-r newbie
Quoted: 0 Post(s)
any documentation?
thanx
fregen gay..
se-rprise is offline
post #16 of 31 (permalink) Old 05-31-2005, 07:45 PM
sleeper
Quoted: 0 Post(s)
just like everyone else.... wondering why you want to convert from a MAF setup to a MAP setup.... I can think if a couple logical reasons, but I want to hear why you want to and also to see if it'd make sense to in your situation.
Khiem
'05 Evo
'05 CBR 600RR
spdracerUT is offline
post #17 of 31 (permalink) Old 05-31-2005, 09:35 PM
Quoted: 0 Post(s)
Well for one you could have just an airfilter on the turbo inlet. No piping. Open atmoshpere blow off. and a few other things. It wont be able to compensate for changes in the barrometric preasure or atmosphere. But it can be effective in some situations. Now my P11 has both a MAF and a MAP.
Nick McCollom
99 Infiniti G20
93 Nissan NX2000 14.027 @97.98 (N/A) I wish I had time and money again, this little car has sat for 2 years now. I do miss driving it bad. It will be back soon though faster than ever.
http://www.cincyclubclub.com/lilly/littlefamily.jpg
sakerocket1 is offline
post #18 of 31 (permalink) Old 05-31-2005, 09:56 PM
sleeper
Quoted: 0 Post(s)
That's actually a performance negative. But it simplifies the piping.
Khiem
'05 Evo
'05 CBR 600RR
post #19 of 31 (permalink) Old 05-31-2005, 10:08 PM
Quoted: 0 Post(s)
not so much on a speed density system. With a maf it is hard to run right.
Nick McCollom
99 Infiniti G20
post #20 of 31 (permalink) Old 05-31-2005, 10:26 PM
sleeper
Quoted: 0 Post(s)
Well, I mean when you recirculate, the air goes back to the turbo at a fairly high velocity helping to keep it spun up reducing lag on the shifts.
Khiem
'05 Evo
'05 CBR 600RR
  SR20 Forum > Main Forums > General SR20
User Tag List
