Old 09-23-2005, 02:48 PM   #1 (permalink)
voiddweller's Avatar
Old Engine: Rusted CAMs - WTF
Hi,
Here are some pics from a highport I just purchased to replace my lowport. It looks like there is rust on the CAMs. What do I clean it with or should they just be replaced?
Thanks!
_______
97 200SX SE-R (Email for lowport parts)
96 240SX (Email for parts)
92 240SX (Email for KA parts)
Low Port to High Port Swap
Garage Epoxy Project
Speak Correct Engrish
voiddweller is offline   Reply With Quote
Old 09-23-2005, 02:51 PM   #2 (permalink)
Coropate greed hater
If there is no rust on the cam lobes, you don't need to sweat it. It does look like someone wasn't turning the crank over to keep the valvetrain lubed while it sat there for however long it did.
-The Usual Suspects
Old 09-23-2005, 02:55 PM   #3 (permalink)
Thanks for the reply. If you look at the top row, third from the left, it's pretty rusted...
Old 09-23-2005, 04:47 PM   #4 (permalink)
not my president
Send that hit back to whoever you bought it from and make them opay shipping thats complete bullsh*t.
1992 nx2000:White: Sold
Danielle Wilson 2/10/07
Old 09-23-2005, 04:52 PM   #5 (permalink)
SR20JET POWERED!!!
it could have sat for a while and just oxidized. it looks like light surrface rust, just hit it with some scotch brite
95 SE-R-SOLD
93 SE-R-RIP(rusted into pieces)
93 SE-R-SOLD
92 SE-R-SOLD
89 Civic drag car
94 G20
Xse-rX is offline   Reply With Quote
Old 09-23-2005, 07:13 PM   #6 (permalink)
Thanks for the info. I picked up a Scotch buffing wheel for for a drill (it says that it's made for light rust) to buff it out.
I'm trying to pull the CAMs off and I don't seem to have an open end wrench big enough to get around the camshaft. What size do I need?
Thanks!
Old 09-23-2005, 07:15 PM   #7 (permalink)
No D E T.
Trader Rating: 18 (100%)
Holy Oxidized Distribtor!
Jonathan Schultz
1997 200SX SE-R U13 Swap
2005 Toyota Avalon Limited
honkeybizkit is offline   Reply With Quote
Old 09-23-2005, 07:28 PM   #8 (permalink)
Whut?That Ain't No Hondah
when you get the motor running, be sure to change out the oil pretty quick, don't want all that crap floating around thru the motor.
1990 2+2 TwinTurbo 300zx
1993 NX2000 (JDM SR20DE-T)
1.6 to DET Swap
Engine Removal Writeup
NissanWar.Com - Pick the Nice from Rice
Like Boxing? Check out FightJudge.com
Crim is offline   Reply With Quote
Old 09-23-2005, 10:04 PM   #9 (permalink)
it's an se-l..not an se-R
Thanks!
A 1" wrench.
I'm irresistable to fat chicks!
DJ P-NOIZE
operation: iraqi freedom combat vet x 3
best time: 14.925@94 2.3 60ft at sacramento raceway without boost or juice
s4's/i/h/e/pullies/g20 ecu
REDSENTRASE-L is offline   Reply With Quote
Old 09-24-2005, 12:58 AM   #10 (permalink)
Making the G breathe hard
Jaketips42's Avatar
Don't even take the cams out. I ran into the same problem with cams sitting around. Put some oil on the lobes and wait about 10 minutes. After, use your finger and rub the oil into the rust. It will turn the oil reddish brown (rust). Wipe it off and repeat until it is all gone. I should have taken pics.
Old 09-24-2005, 03:37 AM   #11 (permalink)
boost virus infects me
Just throw in some S4's and call it a day.
Ben a.k.a Cujo
96 White 200SX SE-R- Stillen Header, 2.5" exhaust, WAI, B&M shifter, Stillen Grille, ADR wheels and Falken rubber
93 Sapphire Blue 300ZX Twin Turbo-Too many mods to list
03 Silver Kawasaki Ninja 636-Yoshimura Pipe
04 White Yamaha Raptor 660R
75 Black Porsche 914
06 Kawasaki Ninja 250R
Cujo_se-r is offline   Reply With Quote
Old 09-24-2005, 09:09 AM   #12 (permalink)
Jaketips42's Avatar
Sh*t, I'll take some S4s if you're handing em out..lol
Old 09-25-2005, 01:02 PM   #13 (permalink)
this is a jdm motor... no one was trying to pull a fast one on you, alot of motors that come from japan are like this espically if the motor has been sitting for a while. you must understand that japan is a very humid place with salt water floating around in the air. i wouldnt sweat the rust too much. its just surface corrosion, i would leave them in there and then change the oil after start up.
THE VE-T IS ALIVE.
-92 sentra vvl-t 470whp...385tq. 24lbs.
-98 sentra SE/ sr2ve powered.
-2005 c230 kompressor.
-2006 Lancer Evolution 9 MR.
http://images.cardomain.com/member_i...66_28_full.jpg
your local asshole.
LanceSR20 is offline   Reply With Quote
Old 09-26-2005, 01:00 AM   #14 (permalink)
Thanks for the suggestions. I decided to leave the CAMs in for now, but I loosend the CAM caps, so I guess I'll need an inch/lb torque wrench to tighten them back down.
Any suggestions on a decent torque wrench that won't break the bank? I'm thinking that this one at Harbor Freight should work fine.
Thanks!
Old 09-26-2005, 07:35 PM   #15 (permalink)
The one and only!!
Thanks!
Looks fine if all you need is inch/lbs.
sil80 is offline   Reply With Quote
Old 09-27-2005, 04:13 AM   #16 (permalink)
Very bling bling
just rub some oil on it and once you get it started change the oil. trust me it will be fine.
http://img9.imageshack.us/img9/4582/jorge11.jpg RIP:1991 B13 a.k.a. Darkness with gen5 HS , CAI, S4's, UR pulleys, courtesy b-pipe, fid_flywheel,ACT extremePP and 6 puck madness. 296,009 miles and no longer rolling. now P10 turbo powered. www.myspace.com/jorgejason77
SuperblkStalion is offline   Reply With Quote
Old 09-27-2005, 07:13 AM   #17 (permalink)
UK N15 Almera Enthusiast
If you do take the cams out a 1" spanner doesn`t always quite fit. I had to grind 1-2mm off the spanner.
rowdy-GTi is offline   Reply With Quote
Old 09-27-2005, 04:23 PM   #18 (permalink)
working on it
swiss's Avatar
Trader Rating: 23 (100%)
Thanks!
You probably already know this, but be sure to tighten those cam caps from the middle out one turn at a time.
Old 09-27-2005, 07:08 PM   #19 (permalink)
Metal Cutting Madman
Trader Rating: 47 (100%)
hell, if you already loosened the cam caps, might as well take the cam out and clean it properly. Block the chain and mark some links/teeth before you remove the cam.
Old 09-28-2005, 02:18 AM   #20 (permalink)
Drive it like ya stole it
SENTRASER's Avatar
Trader Rating: 33 (100%)
zip ties hold the chain on the cam sprokets.
~Ryan
1992 NX2000 Hardtop
1989 B12 AWD wagon
Originally Posted by chriscar
