Ive searched and searched , and i couldnt find exactly what im looking for soo.. Heres the scoop....
I went to sears today to get me some new glasses, parked went in ..came out.. started car and back out of space. I drove about 200-250ft to stop sign and then came to a stop. I went to go back to first gear and nothing. With the pedal fully depressed i had nothing the car would try to roll a tad but wouldnt go in gear. I turned it off put it in gear and drove to the empy part of the lot. I popped the hood and checked the adjustment. it hadnt moved at all so im thinking then...WTF .. I got back in the car and tryed again, same thing wouldnt go in gear for sh*t... Checked and fooled with adjustment .. and finally it worked.. I then drove straight home. I had to work at 5 ,fearing for the worst i didnt drive the car. I Drove my other car. I got home about 12 or so and thought to try it since i was planning to drive it to school tomarrow(2 hours away) and i was thinking maybe it was just some freak thing. Same thing agian wont go in gear. I checked my fsm on this and found some specs but i think its just shot. I have a new clutch and 8.8fly to put in. But what could have caused this? I wasnt bashing on the car, so i dont get it. I guess its jut time for upgrade. Need some help on this one guys whats seem to be the problem? I wont have time to tear it down untill about thurs. So im asking this so i will know what to look for/ replace during the install. And is a new clutch cable reccomended for this install? Thanks for reading and comment's -Devin
"Uncertainty declines when people reduce operations to routines"
Sounds like a clutch problem for sure. One scenario that I know is true with the symptoms you are having is if one of your clutch disc springs popped out and is wedged against the plate and the flywheel. It can work itself into a new spot and then allow you to get it into gear, then if it slings back into a bad spot your stuck again. Turn the car off and she goes into gear easy because the engine and transmission aren't running, therefor you don't need a working clutch to disengage. Clutch cable adjustment and pedal feel will feel exactly the same as a working clutch in this scenario.
Pull the transmission once; every time after that one will be easy, once you learn where to look for the hidden things.
Let us know what ya find. ///H
dint read your story, but same thing happneed to me last week. Turn your car off and put it into 1st, start the car, does it start rolling right away as if your in gear?
My problem was a spring on the clutch broke and my pedal fell to the floor had no feeling. get your clutch replaced.
yeah it wants to roll forward a littel bit and wont go into revers( it grinds) Ill post back in a few hours with the results of my finding's. I have a new clutch and my flywheel should be here either today or tomarrow i ordered the 8.8 from jgy. I wanted to get it from adfab but i called and he and they didnt have any instock, so i had to bite the bullet because i need my car for now. BUt none the less ill keep everyone posted. and thanks for the Help guys. Bye the way is there any special tools i need for the disassembly? also where a good place to get a clutch cable. from what i read nissan is the best, Ive read the adjustment on many aftermarket ones arn't as good? I read a post on a 97cent Brass reducer mod. If the nissan one is too expensive ill get a autozone one and go that route.- Devin
I agree with the clutch spring........ I have done this more times than I care to count.. Good luck, I hope it goes easy for you.
^^^^this would be my response word for word... i'm 99% sure it's a clutch spring where it's not supposed to be. i just went through this crap about a month ago.
93 SE-R with some things and such...
Oh yeah those symptoms sounds familiar. Thanks again for giving me a hand Thomas
Originally Posted by Thomas Reynolds
Only way to tell is to open her up. Same thing happened to Matt Otlsund at the convention this year. We pulled his tranny and there it was. Check it out: http://www.sr20forum.com/showpost.ph...94&postcount=2
Let us know what you found.
__________________ 03.5 G35 Sport 6MT
07 Forester XT Sport 5MT
94 Miata GT28RS powered
93 LS1 240SX Family Project
I used a pry bar, is your spindle disconnected from the ball joint or the strut and tie-rod?You almost need a strait prybar though, the angled ones don't work too well. One thing you may want to replace while you're in there is the clutch release bearing clips. They're like $1.50 and any reputable nissan dealer should have them. Also a new t/o bearing for good measure... Also don't forget to lubericate the t/o bearing rod/leaver arm.
~Ryan
1992 NX2000 Hardtop
1989 B12 AWD wagon
Originally Posted by abelsgotspeed
Originally Posted by chriscar
well its part way out,. and wont go back in, I have the spindle un-bolted from the strut, do i need to unbolt it from the lower control arm as well? or not at all. I have to replace bot clutch and fly, so i need anough space. Please help -devin
Just take the axle out of the hub them drop the tranny with the axle in it.
I used to be a noob but now I'm just a dumbass www.m4exhaust.com
hey whats up, all well the verdict it, the actually clucth broke, pieces ofit fell out as i wiggles the trans out, Got a new problem with the new through out bearing , installed and everything good to go , the car has to pedal pressre??? It has a small amont but it might just need more adjustment? what would cause this? did i do something wrong, it there something in trans i have to pull back out??
give me some ideas I sae where a guy used a 97cents brass reducer from lowes for adjustment>> could that be what i need and why did this happen it was adjusted fine when i took it would, could the flywheel be to blame or the clutch>>> ?? im lost and in need of sleep., but have to get eh car running ill check back in few hours-Devin
yeah, now that i read it your right, ...<<<~~~ (grins) sorry about that, But the car drives well, but the clutch pedal is , about 2 inchs from floor. THe car shifts but i have to pick the pedal back up with my hand to get it to come all the way back up.And the adustment nut is is adjsted all the way up. But i still have no to clutch pedal travel.Im going to lowes now and try the brass reducer mod and see if it helps. and by the way, The flywheel mod is the best mod ive done. car revs like a danm sportbike, cool.. - Devin
get the 1.6 clutch cable. I had the same problem with my B14. The engagment was right off the floor. I even had washers on it. Swapped out the clutch cable and its amazing.
Breathing life back into a fallen NX.
old thread, but fits my problem... 3 weeks ago, i drove about 100ft then couldnt get into gear, would shift fine when car was off,, tried it about a week later and still the same(same roll forward while starting in gear etc), well i finally got my new clutch and went to my car and ordered a tow, while waiting i started it up and it went into gear just fine, was able to drive home.. since i already dropped 400 on the clutch im going to replace anyways, but can anyone tell me what the problem is/was?
