Possible VQ- B13/B14 swap kits... - Page 3 - SR20 Forum
Old 02-27-2006, 01:11 PM   #41 (permalink)
Travieso Racing
Feedback Score: 6 reviews
Originally Posted by unlucky
For those wondering about the VQ30 ECU...
The reason I say to run that ECU, is simply to reduce the wiring nightmare. Few reasons... The VQ35 ECU uses drive by wire technology. This would mean wiring in the gas pedal and making up a subharness for that. The biggest thing, is that ALL VQ35 ECU's come with NATS (Nissan Anti Theft System), which uses a transponder key and matching IMMU. Basically, you would have to get a ECU, IMMU and key, ALL from the same vehicle in order to just start the car. Now, if you have a Consult, or access to one, this isn't such a big deal. However, it still has to be wired up.
If you use the VQ30 ECU, you can get away with using the VQ30 pulley. You have to make a mount for the crank trigger pickup sensor.. but, it's not hard. You don't have to switch the timing cover over.. You use the VQ30 flywheel and VQ30 pickup sensor. This will let you run the VQ30 ECU.
So, using the VQ30 ECU drastically simplfies this install. Yes, you will lose your VTC.. but, it's not THAT big of a deal. You might lose 5-10ft lbs in the low end/midrange. Using a 96-97 ECU means that I can have clark at JWT tune me a nice map to suit the VQ35's demands. So, besides the loss of CVTC function... it's really the best way to go IMO. I mean.. I don't mind wiring up a VQ35 ECU and harness... I had to wire up the NATS system in the Sentra.. and get that working. But, for the average Joe... I don't think most people would enjoy wiring one up. Unless you're really good at reading/interpretting wiring diagrams and voltage/resistance values, adding in resistors/etc where needed... this wouldn't be for the faint of heart.
Travis
lose the vtc? your not done bud... u made something pretty good there but finish the thing.. if some shcmuck in a crx can make his vtec work then u can sure as hell make a jumper harness for that vq35 ecu to work.. not sayin anyhting negative about your swap i like it as a matter of fact but "Make it happen capt".
Danny GDM (HKS)
1993 PRiMERA GT
Old 02-27-2006, 05:04 PM   #42 (permalink)
no reply to using the old VG30 motor?
Mimmsey is offline   Reply With Quote
Old 02-28-2006, 01:54 AM   #43 (permalink)
Trying not to get off topic here, but why would you want to use the VG anyways? Besides a marginal cost factor, the VQ30 would even be a better alternative than the VG IMO. The VQ35 is just straight nasty.
93 Sentra SE-R
Work in Progress
Old 02-28-2006, 01:11 PM   #44 (permalink)
AKA-- JJKAMIKAZE
Feedback Score: 8 reviews
seriously, im selling my 02 mr2 now and building a vq35 b12. make a kit that will work and i will buy it.
NismoTheDog is offline   Reply With Quote
Old 02-28-2006, 02:40 PM   #45 (permalink)
Travieso Racing
u would drive a b12?
Old 02-28-2006, 03:49 PM   #46 (permalink)
B12's ARE THE sh*t!
Old 02-28-2006, 04:07 PM   #47 (permalink)
Is an SE-R/VE a VE-R?
Well if that wouldn't pull the teeth off third in a B13 box I don't know what would. Probably want to plan on a swap to the now virtually nonexistent P11 gearbox. And, the six might indeed be a tad heavier than the four, but my goodness it oughta be interesting in a straight line (accelerating, not stopping - well come to think of it, that might be interesting too - - ).
I STILL think it's a cool idea ***; there may be a few folks out there who'd have a great time with it - I know I spent about that all told on my VE swap.
'93 B13, etc.
do it over and over again?
Old 02-28-2006, 04:58 PM   #48 (permalink)
A good reason not to use the VG30 is the weight, its much heavier, Iron block and all.
Mike
UK-SRi is offline   Reply With Quote
Old 02-28-2006, 06:35 PM   #49 (permalink)
debt or det?
Feedback Score: 3 reviews
just a word on the CVTC thing, how about a set of JWT cams? will they not eliminate the CVTC? maybe i'm way off, i havent paid attention to VQ/VE/VG maxima stuff in about a year now.
also, look around on maxima.org for tilleys99, hes been doing VQ35/VQ30 hybrids for a while.
IIRC, a real nice(read: painless) setup is VQ35 block, VQ30 heads, JWT cams, MEVI (middle eastern variable intake manifold).
all of the VQ stuff is real cheap considering its durability/quality. apparently they're real easy to build too.
make this setup for a P10 and i'm in, otherwise i'll have to wait and find myself a nice B13/B14.
how is the clearance in the enginebay of the spec V? enough room for say, a reverse ypipe and an SC61? maybe a nice intercooler and some pipes??:evil:
i'm very interested in the outcome of this project.
Beakmoney is offline   Reply With Quote
Old 03-04-2006, 02:41 PM   #50 (permalink)
Kichigai 狂 =^..^= 猫 Neko
Gimme, damnit!
Osoroshii kangae nimo osoware mas.
madkat is offline   Reply With Quote
Old 03-09-2006, 08:41 PM   #51 (permalink)
The difference between turning a solenoid on/off, and pulsewidth modulating a continuously variable cam solenoid is HUGE. Vtec is on/off using 12 volts.. that's cake.. just like engaging VVL solenoids.
Travis
Travis Burelle / Forced Induction Racing
VQ swaps, Engine builds, Turbo kits, Chassis work..
985-713-1542 (www.fi-r.net)
unlucky is offline   Reply With Quote
Old 03-09-2006, 08:42 PM   #52 (permalink)
I could fit a single turbo in there, somewhere..
Old 03-10-2006, 12:31 AM   #53 (permalink)
out with neck injury :-(
HJBarker's Avatar
time to start another savings fund, I see...
///H
Old 03-10-2006, 10:19 AM   #54 (permalink)
Travieso Racing
Travis
i believe if youve gone this far with this project you can do anything man. the more you perfect it the more demand youll get for it when people see it hauling ass, or hear it driving by. i fu*k with you bout sc61 but seriously. perfect it.. sell this
Spec'S need all the help they can get
Old 03-10-2006, 10:22 AM   #55 (permalink)
BANNED!!eleven
or maybe use what he says to use....
VQ30DE flywheel
VQ30DE 5spd transmission
"knock knock"
"who's there?"
"cylinder number 3"
Stirpicult is offline   Reply With Quote
Old 03-10-2006, 04:52 PM   #56 (permalink)
debt or det?
how about in a P10? can i be a guinea pig? hahahahhaa
Old 03-11-2006, 01:58 AM   #57 (permalink)
BANNED!!eleven
are the transmission mounts different between the b series and the p series?
if not, just play with the axles.
hahah...a p10 g35.
Old 03-11-2006, 05:05 AM   #58 (permalink)
That sounds good to me, a P10 V35....
I'm in love...
Mike
Old 03-11-2006, 11:34 AM   #59 (permalink)
debt or det?
hahah...a p10 g35.
HAHAHAHA i've never thought of it like that..i'd rather have a P10 G32T though.
i would assume the mounting is the same, because IIRC, the P10 and B13 transmissions swap with the exception of axles.
Old 03-22-2006, 09:02 PM   #60 (permalink)
ser5150
I am very interested in the install kit for a Specv to VQ35. I have both at my disposal and would just need to install kit/instructions and I guess wiring.
Please e-mail me the details ser5150@msn.com
I have a 2005 Spec V Nismo Header, Cat back and cold air right now.
SER5150 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
