Old 03-05-2007, 05:46 PM   #61 (permalink)
NewKleer
confirm the ecutalk.ini is in the same folder as the ecutalk exe, and that its got a line in it something like "Imperial:True"
i just tested it as explained above and it worked fine, so im not sure why it wouldnt work
NewKleer is offline   Reply With Quote
Old 03-05-2007, 05:54 PM   #62 (permalink)
civicdragon
BTCC VE Power
Trader Rating: 16 (100%)
I think I may have found a solution for my Garmin.. I work with Axims and the connector fits but is a bit tight.. i have to look into the pinout for both to see if they match up properly...
now when I get home I'll have to install the software to see if it works as Ive been having trouble getting othr software to run on it...
KL0 P11 Sport
Surround Sound
My VE thread
Old 03-05-2007, 06:25 PM   #63 (permalink)
Blair
wants to go play
Blair's Avatar
Ok I'll try that. Thanks!
93 SE-R (daily driver)
Old 03-06-2007, 05:59 PM   #64 (permalink)
Blair
wants to go play
Blair's Avatar
It's working fine now! Thanks for the help!
Old 03-06-2007, 08:22 PM   #65 (permalink)
NewKleer
cool...most likely it was that u didnt change the tab page to another, since thats not really very intuitive at all (especially since it says u need to restart, logically you would restart from that very page).
Old 04-20-2007, 11:14 AM   #66 (permalink)
chriscar
merely a flesh wound
chriscar's Avatar
Trader Rating: 96 (100%)
WOOT! Got it working on my Axim X5 using the BlaZt serial cable and a Gomadic serial adapter ($45 - ouch).
The refresh rate of V1.3.2 is much much faster than the older version. For some reason RPM & Duty cycle aren't available. I tried it on my 91 Automatic NX2000, and 93 5 speed NX2000 and both were the same.
Would it be possible to program the following enhancements?
-Landscape mode
-Timing / idle set mode. This is one of the most useful features of the 3rd party Consult apps, and would make your program a much more complete solution.
-Sensor / relay manipulation, like selectable cylinder deactivation, radiator fan override, self learn clear.
-Maybe think about reducing the number of color choices for the gauges
Overall, I'm thrilled that it even works. Great job.
Old 04-20-2007, 11:18 AM   #67 (permalink)
civicdragon
BTCC VE Power
so your cost was the x5 and the cable?
I wanna get one but not sure if itlll work since i have a harness adapter from b14 to p11
Old 04-20-2007, 11:22 AM   #68 (permalink)
chriscar
chriscar's Avatar
I bought the X5 a few years ago and it's been sitting in the drawer. If you need to start from scratch, get one of the HP's which are smaller, faster, and have less expensive serial cable options.
The blazt cable was around $80, and the serial interface for the Axim was $45.
Old 04-20-2007, 11:35 AM   #69 (permalink)
NewKleer
doesnt the PDA have a landscape option independant of the program running? if it does, just make sure its used before gauges are shown, as im not sure theyd adjust afterwards.
active tests are in the feature requests page on the site, and will most likely form v1.4 (there'll be another 1.3.x to include things before it like the ability to reconnect after u turn car back on)
colour choices are just all standard ones...obviously depending on screen colour depth, many of them will be the same colour on a PDA (wheres on desktop they will be different). may be useful to just have a colour circle thing rather than named colours, but theres many other important features to go in first
blazt are looking into making a cable up for ipaq's that will do the serial connection + charging:
http://www.blazt.biz/forum/viewtopic.php?t=55
Old 04-20-2007, 11:37 AM   #70 (permalink)
chriscar
chriscar's Avatar
Gotta run - but I want to reply quickly while you're here.....
Any idea why it doesn't show RPM and Duty Cycle as available?
Old 04-20-2007, 01:35 PM   #71 (permalink)
NewKleer
did older versions show them?
i did change something minor in the way it detects them, i guess if older versions worked then its something to do with how i changed it (a few people have said randomly certain sensors wont show up), though theoretically it should work better than it did before (was the reason i changed it at all...and so that duty cycle and other sensors that derive from others only show up if the needed ones do)
Old 04-23-2007, 10:52 AM   #72 (permalink)
NewKleer
group buy for consult interfaces up:
http://www.sr20forum.com/showthread.php?t=196589
Old 04-23-2007, 12:58 PM   #73 (permalink)
classicaddict
this foreum= FAIL
ive read somewhere that consult 2 is backward compatible with consult 1, however i think that is the consult "computers" nissan have are backward compatible, ie support the 2 different protocols. however most (all) consult 1 software i doubt will work with consult 2 cars.
we need someone to get a hand on a consult 2 computer + car and work out how it all works so we can write software for it
i work at a nissan dealer and this is true. useing consult II if you want to use it on an OBDI car you use the OBDI cable and conect it to the consult computer. for OBD II you need to connect the OBD II cable with the OBD II converter on it.
OBD II cable=red plug
OBD I cable= grey plugs
OBD II converter box= medium sized black rectangle on the left (this goes inline between the OBD II plug and the consult box its self)
THIS FORUM HAS BEEN AROUND SINCE 2000........TRUST ME WHEN I SAY YOUR QUESTION HAS ALREADY BEEN ASKED. SEARCH BEFORE YOU POST....PLEASE
please read this link to expand on above.
Old 04-23-2007, 08:26 PM   #74 (permalink)
NewKleer
isnt that "converter" a cable self check device? (since you dont need a converter when u have both plugs on the cable)
my brother works at nissan, he said he might be able to borrow the consult 2 if i ever need it. i did borrow that adaptor, and turns out there is no straight thru connections from one side of the adaptor to another.
Old 08-08-2007, 08:58 PM   #75 (permalink)
NewKleer
beta of v1.3.3 is posted if people want to help testing. its got the "auto reconnect" feature in for PDA users (ie turn car off while gauges showing, then back on and ecutalk will reconnect itself, no need to touch anything) which ive tested and seems to work fine, eg pulling cable, turning pda off, then reconnecting and turning pda back on.
but main thing is i need the 3 new sensors tests - distance, fuel used L, trip economy L (and miles/MPG equivalents), cause im without a car for a while so cant test it myself.
this release (when its complete) will likely be the last minor release before 1.4, which will hopefully have active tests.
edit: link removed, see post below
Old 08-08-2007, 09:53 PM   #76 (permalink)
Saaby
Living up Boost
Will warning levels make this release or 1.4?
-saaby
Saaby is offline   Reply With Quote
Old 08-10-2007, 09:44 PM   #77 (permalink)
NewKleer
new beta: http://www.ecutalk.com/downloads/ECU....3.3_beta2.exe
fixes problems with empty sensor names and program quitting if u choose empty sensor on pocket pc.
only issue found with this beta2 is distance resets after 6.6km. anything else weird let me know
warning levels, active tests will probably be 1.4.
list of tickets that are assigned on the bugtracker page on ecutalk site are ones which will be in 1.3.3. from memory the things left to do:
1) offset value for timing for US users, i think -35 is needed for US users as when 50 is shown for some US cars, it means 15.
2) priority option so that u can lower ecutalk priority if u play mp3 etc or do other things while ecutalk is running.
Old 08-10-2007, 11:51 PM   #78 (permalink)
Saaby
Living up Boost
Excellent work...thank you for your effort!
-saaby
Old 08-11-2007, 07:34 AM   #79 (permalink)
Gnalcarion
...but main thing is i need the 3 new sensors tests - distance, fuel used L, trip economy L (and miles/MPG equivalents), cause im without a car for a while so cant test it myself...
The only gauge of these 3 working on my car is the "fuel used", dunno yet if it's accurate though..
Gnalcarion is offline
