Tokes, keep up the good work. You have serious love for the SR, roller or otherwise. You definitely have earned some serious respect on the forum. Keep it real as always..... we got your back when you need it.
I just found out that the Almera GTi is furnished with the roller rocker a few hours ago. I can't believe this just hit me. Unfortunately there aren't a lot of Almera Drivers here or a lot information on the Almera. I know that I see a lot in the Europe area, and now I am wondering what their engine codes are? Anyone have one want to sign the thread?
1) Dont Know
2) 1996 200sx
3) Yes
4) JDM
5) No Stock ECU
6) I did this swap for my Brother after I blowed his engine and He loves it now I myself Could tell a Huge Differance. Performance wise I advanced the timing it also has a Hotshot header , cold air Intake,lightened Flywheel and Stage 2 Clutch also B&M Short Shifter. It was a straight drop in so it has no emissions stuff what so ever. I Have a B13 Shell that I just picked up and I am starting to do my Fourth SR20 swap and I am considering putting a RR in it. Oh yeah Engine came from Soko just Like all the others I have Bought
7) JHILLSC@AOL.COM
Forgot to mention he also has 2.5 inch exhaust
91 NX2000 JDM ENGINE SOLD
91 NX1600 SOLD
93 SER Classic Work in Progress
Noice... Never knew there were b13's with the swap done... sweet...
for reference:
1) Your Engine Number: (number on driver side by transmission)
2) Car Model & Year
3) Was this engine swapped in? (Yes/No)
4) If Yes for 3)... JDM or USDM?
5) If Yes for 3)... Was a change in ECU necessary?
6) Any other infomation you have to offer (for example, your mods, if you swapped; what you swapped over, what you got rid of, where engine came from, what year you think it is, problems, etc...)
7) Fastest way to contact via internet
Example:
1) 866695A
2) 1998 200SX SE-R
3) Yes
4) JDM
5) No (indicating no change for ECU)
6) I swapped over my intake manifold, had problems with swap. I like long walks on the beach, the engine I had was for an automatic, car has 53J on the head, I got it from Soko. I have an all silver VC. I also switched out my distributor. I had tubular exhaust mani and switched it out, this engine is more peppy, etc.)
7) AIM: xxtokesxx
I believe all the 2 litre Almeras in the UK made after 1996 were roller rockers. But having a P10 and not an N15/16 I could be wrong about the date they changed over.
1) Your Engine Number: no idea, will look later if it's vital, lol
2) Car Model & Year: 2001 Sentra SE
3) Was this engine swapped in? No
5) Was a change in ECU necessary? No, but i have the JWT b14
6) Any other infomation you have to offer: swapped over the b14 intake manifold and sensors (works better with the b14 ecu. after everything was actually connected, no problems. Garrett T3/T04E 57 trim, FMAX manifold, B14 JWT ecu, Z32 maf, Garrett intercooler core with custom end tanks (HP Autoworks), Walbro 255lph fuel pump, Aeromotive fpr, FTF fuel rail, MSD 50lb injectors, Greddy Type S bov, HP Autoworks custom 3" downpipe, VRS exhaust piping with Apexi N1, Tial 38mm wastegate
7) Fastest way to contact via internet: aim- b15chik
boosted 01 sentra se
03 altima 2.5s
well the P10/P11 changeover was done in the factory late in 95 and the bulk of the changover took place in 96, but there are a few leftover dealer stock that were registered for the road in 97. But the FAST dates from the VIN will all be a 95 changeover. But it does seem a few hybrids left the factory as some of the UK guys have P11 gearboxes with P10 engines and vice versa.
Those are not at all common though.
Hi mike, it`s Ian not Neil ....never heard or seen of one, but anything is possible from the Nissan parts bin!
Oooooops Ian,
Sorry, its bad form to get the name wrong, but its unfortunately something I am quite good at. I plead senility.
The P10 changed from highport to spraybar lowport for several years, then it went P11 and RR head at the same time.
1) 3R something... I'l get dressed later
2) UK P10 eGT
3) Was this engine swapped in? Yes
4) UK P11 GT
5) No, still running P10 ECU & Loom.
6) Some mods required to loom and sensors around the intake. Nothing hardcore though, just took an hour or so with the wiring diagrams to figure out. Had to use the injector loom from the P10, and un-bind/re-route some of the wires in the engine bay loom to reach the new locations of the ISCV, etc. Oil pressure sender also changed as plugs were different. Kept the P11 intake, injectors, cam covers etc. Used the P10 distributor with external coil & ignitor. P10 tubular exhaust manifold used. P10 speed sensor, driveshafts used. P10 MAF obviousley. P11 alternator used, only cause it was newer though. Everything else engine & box wise is P11 GT. It all came out & went in from the top, in one big lump box still on and everything. That's all I can remember for now!
1) 726779A (why and what is this number for)
2) 1994 Sentra SE-R
3) Not swap Yet, but will be soon (by the end of Sept) dont ask why...long story. (ok I'M BROKE)
4) JDM
5) Will be using Stock ECU
6) Just bought this motor from jgy <----for good services. I was told that i will have to do some very minor part swap from my usdm sr to the rr motor. jason told me what to do and it isn't much so i guess the swap will be a "yank the dead SOB out-& drop in the new SOB" type swap. I CAN'T WAIT!!!!
7) Right here is the Fastest way to contact me via internet
Oh i might contact some of ya for help thanks!!!!!!
