cylinder 2 STILL not firing
Yesterday cylinder 2 quit on me. Spark was fine. I did some searching found out the injector was most likely the problem. So I tested the injector with an ohm meter, didn't register at all, so the coil must have been broken completely. I bought a new injector today put it on, the car ran fine for a few minutes, then cylinder 2 went dead again. When I first start it, it seems fine, but after a minute or two it quits firing. Any ideas? The only thing left that I can think of is the ECU, is there any way to test that? I am also going to compression test the car later on today.
