now its mounted up.
now goto the auto parts store and buy a 4 rib 29 inch belt.
ull have to take the alternator belt off first but u know that right.lol
next im gonna show you how i removed the Reservor, this can be done in several diffrent ways but this is how i did mine with parts from auto zone.
get a small copper tube cutter and cut the 2 lines here.
buy a 3/8" tee from the hardware store and a hand full of 5/8 worm clamps. also pick up a couple feet of 3/8" fuel line of your choice. make up the loop like this.
also run through the rice asle at the zone and pick up a 3/8" breather and fuel filter.
remove the insides out of the filter.
basicly apply the filer on top of the loop setup you made earlier.a zip tie helps hold it in place
fill the filter up with ps fluid and tighten down the breather. i used an old gear oil bottle to fill it up.
also get a couple cans of brake clean and spray the crap out of everything that got leaked on for a while.
your all done now. first impressions were that i think i need a tie rod lol. u can feel alot now. also it pulls alittle better up top of 4th gear.
i hope this helps
tank
