Old 04-11-2007, 03:46 PM   #21 (permalink)
wildmane
gee, eh? 16...
Trader Rating: 16 (100%)
I definitely have to do this to my project 240.
wildmane is offline   Reply With Quote
Old 04-11-2007, 03:50 PM   #22 (permalink)
Will
oh so LAZY
Originally Posted by webninja View Post
great job - I first read about it here:
http://board.moparts.org/ubbthreads/...fpart=1&v c=1
It's a long ass post, but 69chargeryeehaa painted his charger and it looks fantastic. There is a lot of detailed information scattered in this 20+ page post.
That is the step by step that I used for my car. I plan to wetsand and apply some more coats this summer for a thicker finish.
Click for My Car Pics
White '92 NX2000 All Stock.
Will is offline   Reply With Quote
Old 04-11-2007, 04:35 PM   #23 (permalink)
ekizz
korean domestic market
Okay so I'll try to get this as detailed as possible.
The total cost of the project is roughly 50 dollars. I forgot the individual prices, but it shouldnt be any more than 55.
To prep the car, I first washed the entire car thoroughly with soap, then let it dry.
To the parts that the paint was terrible (like the top of the trunk), i sanded it with a medium-grit sandpaper, then started to use finer sandpaper to get it smooth. After I was done sanding, I washed the car again with soap, making sure to get all the dust off the car, then let it dry.
The paint used in this project is Rustoleum Gloss black, which is essentially a multi-purpose paint (also used to paint houses with). I ended up using only 1 can of this paint, with some left over.
Then the key is to mix the mineral spirits with the rustoleum gloss black. I basically emptied out the entire paint can with all of the mineral spirits, and stirred it throughly with a chopstick. It may seem unusually watery, but this is the consistency we want.
The high-density foam rollers are also a must. Make sure they are the mini ones as well. The little mini-foam brushes also help a ton to get those hard-to-get spots.
I painted my car in the garage, out of the harsh rays of the sun. I attacked each body panel at a time, and slowly progressed around the car until the entire car was painted with the first coat. Make sure that you put on THIN coats. Thick coats are BAD. They drip a ton, and will not be as even. With the mineral spirits making the paint very thin, the paint will dry up very evenly. Also make sure that the paint doesnt leave drip marks on the bottom of the surface you are painting.
I started painting at about 10:00am in the morning, and waited to about 5:00pm to put on my second coat. I started to wet-sand out some of the imperfections in the paint. I had the hose running over the car while sanding it down with a very fine sandpaper. After another thorough wash with soap and water, and getting rid of the dust, I let it dry overnight.
Day 2, at about 11:00am again I put on another coat. This coat came out really good, so I didn't see the need to sand anymore. I waited to about 5:00pm again, and put on my final layer. By then, the car was evenly coated, with that super-glossy ass black paint. To finish the job, I put on the meguiars wax and applied it by hand, then buffed it out again with my hands.
This is probably the best DIY thing there is out there. Guaranteed that a $2000 paint job will look better than this technique, but if you are strapped for cash, and have about 2 days to do the project, go for it!
Eric Kim l 1991 Sentra SE-R l UCLA
Canon EOS 350D l Canon EF-S 18-55mm f/3.5-5.6 l Canon EF 50mm f/1.8 II l Sigma DC 18-200mm f/3.5-6.3
http://www.erickimphotography.com
ekizz is offline   Reply With Quote
Old 04-11-2007, 05:59 PM   #24 (permalink)
worldcrafter
DBA/IT
Trader Rating: 19 (100%)
let us know how long the shine lasts in the sun before having to detail it. I was thinking some cans of clear spray paint (then wetsanding it smooth and polishing) would help
http://www.rollyourcar.com
Old 04-11-2007, 06:51 PM   #25 (permalink)
ekizz
^ This probably would help a ton. But the thing is that I was really strapped for time for this project (I did it during my spring break for my mom's car which is in Norcal...and I'm going to school in socal). Hopefully the wax will protect its shine and whatnot well enough.
Old 04-11-2007, 07:16 PM   #26 (permalink)
Will
oh so LAZY
I do not suggest that anyone try this outside, it needs to be done where bugs and dirt and dust and grass will not get in the wet paint. I had some problems with this even inside my garage.
Old 04-11-2007, 08:09 PM   #27 (permalink)
8pinoy8
Back to N/A route!!!!
Trader Rating: 52 (100%)
AWESOME job.....
1991 NX2000 T-Top ---->Turbo (new toy)
1996 200sx SE-R (soon to be turbo) or may go back N/A
1993 G20 automatic (for the wife)
Looking for some parts, PM me if you have any.
Hazard button for my 200sx SE-R.
Walboro 255LPH fuel pump for a b14
3" cat or similiar for a b14
8pinoy8 is offline   Reply With Quote
Old 04-11-2007, 11:07 PM   #28 (permalink)
BObby12many
Man....
I really wanna do my car in Satin black with this method. But Im not sure it is possible..? Would I just not Buff the pait when I did my finish coat?
THe roll/pad application method seems great. Plus I get %45 off at Sherwin WIlliams due to my job as a paint subcontractor, so All the materials will be EXTRA cheap.
92 P10
-JDM DE
-SSAC Header, 2.5" VRS Exhaust
-UR 4pc Pulley Set
-JGY Street Clutch & 9lb flywheel
-B14 SE-R Trans.
-Pacesetter SS
-Tein Stech & KYB GR2
-P11 Wheels
BObby12many is offline   Reply With Quote
Old 04-12-2007, 12:36 AM   #29 (permalink)
limp_noodle
El Burro
rustoleum makes a clear enamel too. You should try rolling that on and see how that turns out.
http://www.rustoleum.com/Product.asp...ct_id=18&SBL=1
Looks like I havea project this summer
- 02 spec V - lots of crap
- 92 g20 - winter beater/future DET beast. (sold)
- 92 se-r - daily driver
www.njtuners.com
www.highpsi.org
limp_noodle is offline   Reply With Quote
Old 04-12-2007, 12:37 AM   #30 (permalink)
limp_noodle
El Burro
BTW sunrise red comes extremely close to Nissan's Aztec red.
When you painted the car did you do the bumper as well? Any idea if it'll crack w/ no flex addatives?
Old 04-12-2007, 01:07 AM   #31 (permalink)
Bo0sT
WOW dude that looks like it came out of a body shop. Good job.
I've had a 94, 92, and 93 Sentra SE-R (in that order), and none of them have ever left me stranded.
Push it to its limits. Then push it past its limits. Then rebuild it with better parts.
Bo0sT is offline   Reply With Quote
Old 04-12-2007, 06:17 AM   #32 (permalink)
hpro123
SE-R GREEK
Maybe you can specify quantities here?
"Entire paint can and with all of the mineral spirits" is subject to interpretation, right?
Old 04-12-2007, 03:10 PM   #33 (permalink)
limp_noodle
El Burro
did you primer the car first, or did you just paint right after your sanded it down?
Old 04-12-2007, 11:29 PM   #34 (permalink)
ekizz
^no primer needed. you just sand down that bad baby and put on the paint.
so this is my mixture: (response to hpro123)
1 qt rustoleum paint
30 fl oz mineral spirits
Old 04-13-2007, 02:33 AM   #35 (permalink)
DanniNX
suspected eskimo
I'd recommend using real paint (ppg, dupont, glasurit, sikkens, spieshecker etc.) with hardener, you can use the same process with that and it will stay shiny and be much more resistent to weather and chemicals.
Also, I recommend using a degreaser rather than soap and water before painting.
1992 Sunny GTi-R (151.000km) EGNN14 - LHD 4wd turbotoy.
DanniNX is offline   Reply With Quote
Old 04-13-2007, 09:10 AM   #36 (permalink)
Fonque
broke, busted and rusted
I may have to give this a shot this summer.
Fonque is offline   Reply With Quote
Old 04-14-2007, 03:57 PM   #37 (permalink)
Will
oh so LAZY
you want it watery so that there are no little dimples in the paint when you roll it on, which will happen if its thick at all.
Old 04-27-2007, 02:18 AM   #38 (permalink)
2dr_sentra
Slut Butter
Trader Rating: 31 (100%)
i am doing this to my b13 soon, i am primering the car as of now. this thread is the sh*t!
you should make a list of everything you used, like name of brushes if you can.
97 200SX SE-R w/SR20DET and S4 cams
2007 Versa SL 6speed
http://i10.photobucket.com/albums/a1...illsbabies.png
Old 04-27-2007, 03:47 AM   #39 (permalink)
JTM
My sister is JDM, I'm JTM
I have a spare hood and trunk for my Eagle Summit, maybe I should try doing the poor boy carbon fiber (AKA:black) hood and trunk.
1994 Eagle Summit ES 5-spd
1996 Dodge Caravan
1996 Nissan B13 Sentra
http://www.cardomain.com/id/JTM204
JTM is offline   Reply With Quote
Old 04-27-2007, 12:59 PM   #40 (permalink)
Will
oh so LAZY
you really do not need to primer it at all.
