Old 05-29-2007, 07:12 PM   #1 (permalink)
the ONLY nx in schaumburg
how to check tps voltage
i know that i need a volt meter to do it and i have one but the tps in my 91 nx has 3 connectors(wires) coming out of it?????how do i check it if the voltmeter only has two sensors????
pedronx2k is offline   Reply With Quote
Old 05-29-2007, 07:16 PM   #2 (permalink)
Broke Ass
jer_760's Avatar
One lead goes to wire on the tps, the other lead goes to a ground.
95 200sx
sr20ve
Old 05-29-2007, 08:31 PM   #4 (permalink)
SE-R Project Lover
Pull off the connector for the throttle position sensor, and read one of the leads as the other guys have said. At closed throttle the reading should be less than 1 kilo-ohm and at full throttle it should be at about 10 kilo-ohms I believe. I can't remember which one it is, though. By the way, instead of using the battery ground I believe you actually get a more accurate reading by using the ground terminal on the sensor.
Rick
RabidRaccoon is offline   Reply With Quote
Old 05-30-2007, 11:56 AM   #5 (permalink)
thanks guys much help as always
Old 05-30-2007, 02:24 PM   #6 (permalink)
ok so the readings im getting dont make sense. at closed its zero but at wot its.88??what am i doing wrong?what setting on the voltmeter do i use??
Old 05-31-2007, 09:28 AM   #8 (permalink)
change isn't always good
I never did it been when I was searching for this answer I found that you leave the connector plugged in. Jam the probes into the back of the connector, one in the middle and it doesn't matter which wire the other one goes in. Turn the key to the on position but do not start it. Move the throttle from under the hood slowly and watch the volt meter. If you have the wires switched it won't matter you will just have a - in front of the number.
Again I state I never did this but found this info on g20.net. I will see if I can find the post.
"The search button is like GOD, it has ALL the answers"
99t 196whp @6.5 lbs!
GTR manifold, GT28r, Precision front mount, 1g BOV, Greddy E-manage, Stillen pop-charger, Nismo FPR
robkris8079 is offline   Reply With Quote
Old 05-31-2007, 08:23 PM   #9 (permalink)
thanks i will try again
Old 05-31-2007, 11:12 PM   #10 (permalink)
so i tried again........throttle closed the meter said 0.0???? and WOT it said 0.66......wtf i tested it from the back of the sensor plug.middle wire and the ground??WTF??
Old 06-08-2007, 03:15 PM   #11 (permalink)
'87 Pulsar NX on steroids
0.4 to 4.0 on volts..
1K to 10k on ohms..
If you are getting different measurements, either you have to adjust it or your TPS is screwed and needs to be replaced.
BTW, the mechanical part in the TPS can be cleaned?
MC
NX Club de Costa Rica
__________________________________________
Why should I shut my mouth... if I was born yelling...
mcalvo_cr is offline   Reply With Quote
Old 06-08-2007, 09:03 PM   #12 (permalink)
can it?????????
Old 10-06-2007, 09:05 PM   #13 (permalink)
so i just tried this agian and i got .31 closed then 3.3 at wot .........thats not right? is it
Old 10-06-2007, 09:17 PM   #14 (permalink)
i should use the middle wire and the top wire on the tps ?
Old 10-06-2007, 11:14 PM   #15 (permalink)
this foreum= FAIL
i think it would be so much better if someone who has done this before simply took their DMM and placed the probes in the correct location for testing then just took a pic. i plan on doing this soon and have a general idea of how to do it, but a pic is always worth 1000000000000000000 words.
Old 10-06-2007, 11:20 PM   #16 (permalink)
banned
Trader Rating: 31 (100%)
Nevermind
Wicked R is offline   Reply With Quote
Old 10-07-2007, 06:09 PM   #17 (permalink)
Light weight thinker
OK,
I tested the TPS both ways. Doing resistance, I couldn't really get a good pic of the leads because I was using alligator clips. It's easier when you have them for doing the resistance, but you must make sure you don't have too much resistance through the clips. I had about 5 ohms.
Pic of the car in the garage :-)
Leads for resistance measurements. I used the center pin, and the one on top of that. Hard to get a good picture of this.
Resistance reading at idle. Notice the DMM range selection. Yummy, 997... One of my favorite numbers, aside from 993, and 917-30 :-)
Resistance at WOT. Notice again I've changed the range of the DMM.
Leads stuffed in the back of the connector to measure the voltage.
Voltage at idle.
Voltage at WOT.
When doing the voltage, the leads will pretty much just stay in the holes. Again, I used the middle pin, and the pin on top, but I connected the common (black) to the top pin and the red to the middle pin to get a "positive" voltage. It doesn't matter if you go the other way with it and get "negative" readings, but the positive numbers just make you happier.
Derrick
"It's better to go into a corner slow and come out fast, than to go into a corner fast and come out dead" - Stirling Moss
piratetrucker is offline   Reply With Quote
Old 10-07-2007, 06:47 PM   #18 (permalink)
this foreum= FAIL
thank you very very much. i was really just after a pic of the EXACT wires you want to test. this helps alot.
Old 10-07-2007, 07:52 PM   #19 (permalink)
sweet thats what i neede!!!!!!!!!thanks a bunch!!!!!!!!will try again and post my readings.......
Old 10-07-2007, 09:33 PM   #20 (permalink)
ok,so i just did this again and thers two settings on the mm,and i used the vac/not vdc setting...and when closed i got 341.36!!!!???wtf??...but *** i move the throttle a lil tiny bit i can get the meter to read .3 or .4 but no other numbers(decimal piont) after that. but at wot i get 3.9-4.1......
