Car jerking when accelerating??? - SR20 Forum
post #1 of 31 (permalink) Old 12-22-2007, 02:49 PM Thread Starter
Quoted: 0 Post(s)
Feedback Score: 40 reviews
(Thread Starter)
I am having some major issues with my car right now. Everytime I accelerate the car starts to jerk out of control, The only way to stop it is to press in the clutch and start over. I can't seem to figure out if its clutch,fuel,or motor/turbo related. I am first going to replace the clutch cable to see if the clutch just isn't disengaging and maybe sticking?? Another weird thing it does is when you try to accelerate it'll start to jerk, but if you gun it it starts to stumble and jerk, then take off. After I change the clutch cable I am not sure what else to try and will just do the engine swap, change out the clutch, etc.... Any input would help.
btw I am planning on swapping in a jdm de soon and bigger turbo set-up;, but wanted to atleast get through the winter to do the swap(to damn cold), and right now the car is basically undriveable.
91 SE-R: SR20DE (soon to be stock)
jonwepa is offline
post #2 of 31 (permalink) Old 12-22-2007, 04:37 PM
94 JDM SR20DE XE
Quoted: 0 Post(s)
Have you checked the ecu for codes? I would start there and see where that takes you.
philipn126 is offline
post #3 of 31 (permalink) Old 12-22-2007, 04:51 PM
officially a boost addict
Quoted: 0 Post(s)
Feedback Score: 10 reviews
sounds like a fuel problem to me....
plugs possibly?
what's the a/f look like?
http://www.sr20-forum.com/members-ri...ebs-build.html
U13 SR20DET, Turbonetics 60-1 hi fi .63 ar, Brian Crower Stage 2's, 875cc injectors, .3 bar fuel pressure, log manifold, Tial 38mm wastegate, 3" downpipe-3", PLX Wideband, Megasquirt v3.57
Balls to the wall until you see God, wait ten seconds then hit the brakes...
www.performanceplusky.com
nsusammyeb is offline
post #4 of 31 (permalink) Old 12-22-2007, 05:50 PM
4th sr20 and counting..
zipstrips's Avatar
Quoted: 0 Post(s)
Feedback Score: 21 reviews
plugs vac leaks and check your timing!
SHIFT_multiplication!
01. Audi TT 225
98. the zips machine
95. t28 setup
95. Celica, 3SGTE
90. Miata BP swap
zipstrips is offline
post #5 of 31 (permalink) Old 12-22-2007, 05:56 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Have no light on, but no I haven't checked that. Didn't even think of the obvious
jonwepa is offline
post #6 of 31 (permalink) Old 12-22-2007, 05:58 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
plugs possibly?
A/f seems to be good by looking at the plugs, there nice and rusty colored.
jonwepa is offline
post #7 of 31 (permalink) Old 12-22-2007, 05:59 PM
Quoted: 0 Post(s)
Def. check your plug gap if you put them in recently and check for vacuum leaks.
doner005 is offline
post #8 of 31 (permalink) Old 12-22-2007, 06:03 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Plugs are perfect, I've had a vacuum problem since day one and just can't seem to find the culprit, but it never caused any problems before and my timing is fine although I really can't get it running right let alone put it into timing mode.
jonwepa is offline
post #9 of 31 (permalink) Old 12-22-2007, 06:05 PM
Quoted: 0 Post(s)
most likely a vacuum issue then.
doner005 is offline
post #10 of 31 (permalink) Old 12-22-2007, 06:15 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I am positive its not because its been the same since i turboed the car (a year ago) and the car ran great. It is the reading the same at idle as it was before.
jonwepa is offline
post #11 of 31 (permalink) Old 12-22-2007, 07:06 PM
Quoted: 0 Post(s)
so there's no cel's? Sounds to me that it is either flooding when you put it to the floor or leaning out and detonating. Most likely flooding the cylinder with fuel, and then once it gets more air in there in leans out enough to run smoother. Check your injectors, any of them leaking or stuck open? How's the compression??? Throwing out ideas, but i agree with zips it's most likely a vacuum leak. Car idle at all? Here I have a video of mine idleing with a really big vacuum leak... http://s71.photobucket.com/albums/i1...t=HPIM0929.flv
It would do the same thing really rough until I got high enough in the rpms to overcome the vacuum and it would smooth out... http://s71.photobucket.com/albums/i1...t=HPIM0928.flv
hopefully this helps you some.
What clutch is in the car? What turbo set up do you have? How much power you putting down?
post #12 of 31 (permalink) Old 12-22-2007, 07:10 PM
zipstrips's Avatar
Quoted: 0 Post(s)
what ECU do you run?
01. Audi TT 225
95. t28 setup
95. Celica, 3SGTE
90. Miata BP swap
post #13 of 31 (permalink) Old 12-22-2007, 07:21 PM
Big Cheddar fan club
erick212's Avatar
Quoted: 0 Post(s)
Feedback Score: 7 reviews
When is the last time you changed the cap and rotor? I would just for the piece of mind change the plugs. You would not believe how many times it was just a simple plug change...even though they looked o.k. If you could list your setup it would make other diag.. easier. If you have sometime you can use to datalog that would be great also.
Erick
06 Frontier
low post count=working on cars more than computers
SR20deep Ct.
erick212 is offline
post #14 of 31 (permalink) Old 12-22-2007, 07:50 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Your explanation sounds like the most accurate, but the only thing is wouldn't the plugs show signs of the detonation?? The plugs are about 1 month old and look really good(gapped to .028. My compression has been steadily declining(175,000+ miles), but is still reading 150 across all 4 cylinders and the vacuum problem has always gave me issues with my idle, but not my acceleration or drive ability, which can be seen by my 1/4 mile times.
My main guess is the clutch. It feels like its not disengaging properly and sticking maybe ??? Almost like when you don't let the clutch out right and it jerks like crazy and I am using a cheap xtd ebay clutch, which has never given me a problem and held up to multiple track runs and a 13 flat @ 110mph.
My next guess would also be a leaky injector, but would it start to misfire? and not jerk??
jonwepa is offline
post #15 of 31 (permalink) Old 12-22-2007, 07:58 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
btw this is my set-up: usdm w/ 175,000 miles, bb manifold, avenir t25, 370cc's, nismo fpr, bored se-r maf, hot shot fmic w/ hks bov recir., jwt s3 cams, jwt ecu tunned for the above set-up @ 4bar fp, 3inch dp w/ side exit exhaust, etc.... I run at the track pretty frequently and run low 13's @ 108-110mph. I have never been to a dyno yet, but by my traps and times I am guessing around 250??
jonwepa is offline
post #16 of 31 (permalink) Old 12-22-2007, 08:37 PM
Quoted: 0 Post(s)
i actually have one of those stage 3 xtd's in my car and i like it haven't had any problems so far, and it's very streetable. When you say jerk you mean like "jerk" not just a gap in the power band? I mean you're the one driving what's it feel like? It's hard for us to troubleshoot haha, we're just throwing ideas out there. My girlfriends car has oil on one of the plugs and it kinda jerks when you give it some gas, but doesn't do it if you really get down on it. You may just have one cylinder misfiring somehow. I'd check the injectors with a 9 volt battery and a couple wires, you'll hear them click open and closed, it's pretty cool actually.
post #17 of 31 (permalink) Old 12-22-2007, 08:42 PM
Quoted: 0 Post(s)
you have a boost guage on the car don't you?? does the vacuum on it bleed off while it's idleing?
post #18 of 31 (permalink) Old 12-22-2007, 08:54 PM
Quoted: 0 Post(s)
Feedback Score: 12 reviews
I had a TPS that went bad. It would stumble as it accelerated. Does it feel like it's cutting in and out real fast with it normal in between the times it cuts out? You can watch the TPS on a consult and see this happen. It did not show when I did a tps setting but if you watched the voltage as you slowly opened the throttle you could find dead spots.
Steve
98sr20ve is offline
post #19 of 31 (permalink) Old 12-23-2007, 01:06 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
At idle my boost gauge reads about 10 and usually stays there.
I did check my tps and it read .44 with the ignition set to the on position and at WOT it reads 4.15. I took it off and cleaned the contact points, but still nothing. Now my idle is just plain crazy one minute its idling at 900rpm the next its stalling and then its idling at 2000rpm. I know that my low vacuum is probably not helping this and maybe even causing this.
jonwepa is offline
post #20 of 31 (permalink) Old 12-23-2007, 01:12 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Thats the one I have and I haven't had any problems with it either. I think its a little of both. It feels like a dead spot and a jerky clutch
I think I will do a injector test next.
jonwepa is offline
  SR20 Forum > Main Forums > General SR20
User Tag List
