Old 03-22-2008, 01:21 AM   #1 (permalink)
SR20WhoKnew
Cruise Control Question ! -_-
How do you use it? haha. I have a 98' SE-R and I've been driving it for
about a year and a half and I never used it. Do I just press the button
on the steering wheel? Is there a certain speed that it could start working?
Could someone basically tell me how to enable it and turn it off?
Thanks
98' 200sx SE-R
- JWT Pop Charger
- High Port Cam
- Gen 1 HS header
- 2" Stromung cat-back exhaust
AutomaticTransJAIL !
SR20WhoKnew is offline   Reply With Quote
Old 03-22-2008, 01:37 AM   #2 (permalink)
SE-RiousStyle
when you are over 55 mph hold the button on the left down that says cruise , till it turns green then push down cruise controll button on steering wheel. that's it
SE-RiousStyle is offline   Reply With Quote
Old 03-22-2008, 01:38 AM   #3 (permalink)
SE-RiousStyle
then hit the nos
ha ha
Old 03-22-2008, 02:00 AM   #4 (permalink)
Syne'
B13 Classicism
hehe i love my CC! i use it all the time on the freeway this way i wont get an itch to push the gas pedal more
Syne' is offline   Reply With Quote
Old 03-22-2008, 02:14 AM   #5 (permalink)
SR20WhoKnew
Well I was looking at the cruise control line and I found this. Will my cruise control work if this line ain't
in all the way?
Old 03-26-2008, 11:36 PM   #6 (permalink)
SR20WhoKnew
bump anyone???
Old 03-26-2008, 11:38 PM   #7 (permalink)
CovertRussian
Most likely not....
We are a community
Can mainly find me and my posts at www.sr20-forum.com under name "Vadim"
CovertRussian is online now   Reply With Quote
Old 03-26-2008, 11:46 PM   #8 (permalink)
SR20WhoKnew
Does anyone know what kind of line is needed to replace the broken one?
Old 03-26-2008, 11:49 PM   #9 (permalink)
jer_760
Broke Ass
jer_760's Avatar
Any vacuum line that fits will work. Also, I think you have to be going above 20mph for it to work, not 55.
95 200sx
sr20ve
Old 03-29-2008, 08:58 PM   #10 (permalink)
WingmanSR20
MECP Master Installer
WingmanSR20's Avatar
Yessir, has to be over 25 to work...some vehicles have the low point as high as 30 though!
1997 200sx SE-R
1999 BMW Z3 Roadster
Old 03-30-2008, 09:07 AM   #11 (permalink)
ishkabibble
Just cut the cracked end off and plug it back in. If your are bent on replacing it, you can buy bulk Goodyear vacuum hose at Autozone for a few dollars. just bring the old hose in to match it up.
ishkabibble is offline   Reply With Quote
Old 03-30-2008, 06:28 PM   #12 (permalink)
ishkabibble
I replaced mine today. It's a 5/32" hose.
Old 04-26-2008, 08:31 PM   #13 (permalink)
SR20WhoKnew
Well after I replace the hose, the cruise control should work correct? Or is
there anything else that has to be checked? Thanks
Old 04-26-2008, 10:05 PM   #14 (permalink)
WingmanSR20
You'll find out if it doesn't work with that hose in. The beauty of troubleshooting. Process of elimination. Get that hose replaced, look at diagrams, check the components. We're here to help, but by no means hold your hand.
Old 04-26-2008, 10:08 PM   #15 (permalink)
SR20WhoKnew
Alright, thanks for the words of wisdom
