Originally Posted by Ianh
Do you guys plasi-gauge the bearings to make sure the clearance is in spec when re-assembling.
I'm about to do this to my motor since I'm waiting on bearings from GregV.
I have my own question for you guys. When I'm ready to permanently install the replacement rod bearings...do I apply lube between the bearing and rod/journal surfaces? Or do I keep that area clean/dry?
Can I use brake cleaner to clean those surfaces?
