Old 04-18-2008, 06:52 PM   #1 (permalink)
E-rocks nissans
Get naked then get in
upper oil pan torq specs
any idea ?
Classic 93 Black SE-R, Bone Stock
E-rocks nissans is offline   Reply With Quote
Old 04-18-2008, 07:25 PM   #2 (permalink)
myprojectB13
myprojectB13's Avatar
Trader Rating: 16 (100%)
90% sure it's 12-14 ft/lbs for the M8 bolts.
Jonathon
1996 G20
1993 SE-R 13.66@101
Old 04-18-2008, 07:44 PM   #3 (permalink)
dxpxe
in a word ...... snug
dxpxe is offline   Reply With Quote
Old 04-18-2008, 07:51 PM   #4 (permalink)
ashtonsnissannx
SR20 Finatic
yeah i was gonna say, tight, i usually tighten them holding the 3/8 ratchet at the head and turn it like that until tight, then bump it a little more and its good, they dont ever come loose when tight.
92 Nissan Sentra SE-R
Current mods:Soko JDM 9.5:1, Prothane Motor Mounts, S13 Tubular Manifold, S13 T25, S13 Greddy 3" downpipe, FMIC 2.5" piping, Turbo XS RFL Bov, JWT S4's, STI 520cc injectors @ 4 bar pressure, Calum ECU, Fidanza 8.8 lb flywheel, ACT Extreme PP w/4 puck unsprung disk.
Turbod feels awsome.
ashtonsnissannx is online now   Reply With Quote
Old 04-20-2008, 11:28 AM   #5 (permalink)
E-rocks nissans
how about the specs for the pressure plate and clutch
Old 04-20-2008, 11:50 AM   #6 (permalink)
ashtonsnissannx
SR20 Finatic
tight about the same maybe a little tighter., they have lock washers on them do not overtighten or you will do what i did and snap one off in the flywheel. haha. came out easy but still. and it was the last bolt. sucks.
Old 04-20-2008, 05:06 PM   #7 (permalink)
dxpxe
some people will swear that the flywheel and clutch get a certain amount of torque otherwise hotspots will be created causing bolt failure.
but ive always just given it a good "umph"
my be someone you wanna look up as everyones "umph" isnt the same
