Old 04-25-2008, 03:03 AM   #1 (permalink)
Chadwick
06/08' FREEDOM!!
VC gasket/dialect grease question
so i installed a new valve cover i got from another member and i bought a new valve gasket and what not. no leaks around the out side but oil leaked into the two left spark plug wells through the O gaskets/rings. i used my old O gaskets/rings and the same thing is happening so im guessing its the valve cover.
im wondering whether i should be using dialect grease around the O gaskets rings? im in the process of doin this and putting the mkIII lip on right now so any help would be great.
95' B14 SE-R
New (03/27/08')
Joined the dark side
http://www.sr20forum.com/members-rid...-b14-se-r.html
Chadwick is offline   Reply With Quote
Old 04-25-2008, 04:20 AM   #2 (permalink)
Chadwick
06/08' FREEDOM!!
bump bump bump! im goin to jail tomorrow and need this thing fixed. HEEEELLLLPPPP!!
Old 04-25-2008, 03:20 PM   #3 (permalink)
Chadwick
06/08' FREEDOM!!
ok so i put the old valve cover on. and im still having the same problem. WTF! i need my car driveable by today considering im going to be on work release for 2 months so i wont be able to work on it. this is pissing me off. is it safe to slap that dialect grease on the O rings/gaskets that go around the spark plug wells? its only the two left spark plug wells that are leaking.. i cant even see the spark plugs.. i dont know what the problem is.
any advice is well preciated. helllppp!! pleaseee!!
Old 04-25-2008, 04:49 PM   #4 (permalink)
swiss
working on it
swiss's Avatar
Trader Rating: 22 (100%)
You are supposed to tighten them in a specific order, to a certain torque. Look at this (ignore the stuff about cams, just look at the beginning and end for VC info):
http://www.geocities.com/n_dahi/cams/cams.htm
Old 04-25-2008, 07:34 PM   #5 (permalink)
Chadwick
06/08' FREEDOM!!
yeah i did everything in the right order. iv talked to alot of people about it and its really wierd that its doin this. i bought some gasket in a can stuff and im just going to seal the sh*t out of them for now. lattte guys. im off for 2 months. thanks for all the help so far.
