Old 04-25-2008, 11:19 AM   #1 (permalink)
n1smojunkie
Transplant was a sucess
Trader Rating: 4 (83%)
Bad battery? Or something electrical...
Coasting to a stop in my p10. All of a sudden my ABS light, battery light, and e-brake dash lights pop on and stay on. the cluster got a lot dimmer and the electric windows were sooo slow. This my alt? Maybe the belt? I just hope its not electrical.
Whats your 0-60...? Fast.
1998 Nissan Sentra-SOLD
1971 Datsun 240z-Moms
2004 Nissan 350z 6MT-Moms
2007 Infiniti g35 coupe-Dads
1992 Infiniti g20 5mt-Daily
2003 Infiniti g35 sedan-Girls Car
(\__/)
(O.o )
n1smojunkie is offline   Reply With Quote
Old 04-25-2008, 11:37 AM   #2 (permalink)
92serturbo
Holy Fireballs Batman!
did you check the tension on the alt belt? sounds like an alternator issue.
*Alex Stanley*
03 VW GTI 20th Anniversary #0918
92serturbo is offline   Reply With Quote
Old 04-25-2008, 12:07 PM   #3 (permalink)
WingmanSR20
MECP Master Installer
WingmanSR20's Avatar
x2 on the alty. Check it out, make sure the pulley isn't loose on it, make sure the belt is tight, make sure it's fully connected to the harness.
1997 200sx SE-R
1999 BMW Z3 Roadster
Old 04-25-2008, 01:35 PM   #4 (permalink)
budgetNX
SR20DEEEEEP
i used to have the same problem, i did have the little 10mm bolt that was like a lock, so my alty would come loose going over sh*tty roads and slid down, making the alty come out of the belt.. sh*tty times
http://www.myspace.com/beat_a_bitch
Originally Posted by Shawn B View Post
Then you get pissy, belligerant, and your panties get bunched up when someone, namely me, tries to actually help you with a couple of links?!?
Are you f*cking kidding me?!?
You sir, are an unmitigated selfish, egocentric, self-absorbed, DOUCHEBAG and can go f*ck yourself.
budgetNX is online now   Reply With Quote
Old 04-25-2008, 01:45 PM   #5 (permalink)
n1smojunkie
thats what i figured. ill check it out when it warms up a bit outside.
Old 04-25-2008, 04:19 PM   #6 (permalink)
n1smojunkie
everything looked good. the dummy lights are still stuck on though. i have an hid kit on the car...one of them popped out of the housing and bounced around and then this happened. ideas?
