Old 05-01-2008, 03:30 PM   #21 (permalink)
NissanSpeed01
It sounds like you guys switched the Distributor plug with the O2, sensor plug. The car will seem like it has spark but wont start. If you do this, it will also fry your ECU and give u ignition codes.
NissanSpeed01 is offline   Reply With Quote
Old 05-01-2008, 09:20 PM   #22 (permalink)
stealthaltima
slick-graphics.com
If this was the case the injectors wouldnt click and the fuel pump wouldn't turn on when turning the dist. shaft. right?
'94 B13
'91 P10
stealthaltima is offline   Reply With Quote
Old 05-02-2008, 07:33 AM   #23 (permalink)
NissanSpeed01
No, the injectors will still click, and the fuel pump will still turn on
Old 05-06-2008, 02:55 AM   #24 (permalink)
stealthaltima
slick-graphics.com
Honestly, I dont think we can be talking about the same thing.
1. The plugs aren't even the same [at least on my 94 SE-R, 91 G20 and 93 G20]
2. How could turning the dist shaft signal the ecu to turn on injectors and the fuel pump if it is plugged into the O2 sensor plug [even though it is impossible for me to plug the CAS into the O2 sensor plug. ]
So it turns out in the confusing of things I really slipped up and put the cams 180 degrees out. So next thing is a compression test. I hope to god I didn't mess up this motor.
Lesson to be learned:
1. Don't work on vital things when you are pissed off.
Anyone else???
Old 05-09-2008, 01:46 AM   #25 (permalink)
stealthaltima
slick-graphics.com
No one else???
This thing makes me feel like an idiot.
Old 05-09-2008, 10:03 AM   #26 (permalink)
WingmanSR20
MECP Master Installer
WingmanSR20's Avatar
You said you put the cams on 180degrees off. I guess I'm not sure what else you're looking for?
1997 200sx SE-R
1999 BMW Z3 Roadster
Old 05-09-2008, 12:25 PM   #27 (permalink)
NismoSER
VE powered on 12/9/07 :-)
NismoSER's Avatar
Trader Rating: 16 (100%)
How did you put the cams in 180* off? Don't the dowel pins only allow you to put them in one way? Or did you completely flip the entire cam gear and cam????
Chris
'91 VVL-powered SE-R
'04 G35 6MT
Old 05-10-2008, 01:58 AM   #28 (permalink)
stealthaltima
slick-graphics.com
That is already resolved
Long story short... the chain slipped off the sprocket and the mtoor got set to BDC and I lined everything up, thus 180out.
I was fighting with the [now ex] girlfriend and I buddy of mine was helping me. Last time I trust him.
I dont really care about any of that now, just trying to drive the thing.
What sucks it Im really limited to when I can work on it. We'll see....
Old 05-10-2008, 09:26 AM   #29 (permalink)
WingmanSR20
Sow what's wrong now? You told us:
To me, that's saying you found out what's wrong. Unless I missed a day at school or something.
Thats 90* off. TDC happens twice on each system, cam alignment once.
180* off is if you aligned the cams at the second TDC of Cyl #1. The timing would look right when you checked it, but the engine would have intake strokes and exhaust strokes all mixed up.
