Old 04-27-2008, 12:23 PM   #1 (permalink)
Rittmeister
The Groove Master
Rittmeister's Avatar
ECUTalk + NissDataScan - Help!
OK, so I've got a NissDataScan CONSULT module from Australia, and I've got an old laptop onto which I've loaded ECUTalk (hey, it's free). I'm having problems getting the Consult module to communicate properly with the computer.
So, I'm trying to find out in what sequence I should be turning things on. Here's what I've got:
Laptop (connected to NissDataScan via a serial cable, which I assume is COM1 in the software)
ECUtalk software
Car with Consult module (NissDataScan)
RS232 mode in Consult module.
What I did was connect the cable, turn on the computer (so it would recognize the connection, I hope), fire up the car, and switch the DataScan to RS232. At this point, the ECUTalk software told me that the connection had failed and it would try again in five seconds. Did this repeatedly. I have tried other COM ports in the software with no success. I also tried re-starting the computer, thinking that maybe the car/Consult reader had to be active to be recognized by the computer, but it didn't work.
I feel like this should be a simple thing, but I can't figure it out - unless the ECUTalk just won't work with the NissDataScan module.
Any help GREATLY appreciated.
1990 240SR - the DET has landed.
Kent's Funkay Disco
Old 04-27-2008, 01:08 PM   #2 (permalink)
Doug_O
Big Bossman
Doug_O's Avatar
I have been through my share of connection problems with my LC1 and Consult cable, and it all came down to how I had setup my serial to USB adapters. I had to play with the baud rates/buffers to finally get them to work.
I don't know if you fall in the same boat, but just a thought.
Doug
Money Shot
12.5@110
Doug_O is offline   Reply With Quote
Old 04-27-2008, 01:32 PM   #3 (permalink)
Rittmeister
The Groove Master
Hell, I don't understand any of that stuff
I'm not using a serial-to-USB though, just a straight serial connection (this is an older laptop that acutally has a serial port).
Old 04-27-2008, 05:58 PM   #4 (permalink)
Doug_O
Big Bossman
Doug_O's Avatar
Wow serial ports. Yeah it's an old laptop
Nevermind on my post.
Doug
Old 05-02-2008, 01:25 PM   #5 (permalink)
det-ser92
Slow down? Maybe..
det-ser92's Avatar
Try going to Blazt.biz and getting some info. If you haven't tried already. I had a similar problem with mine and ended up just having to re-register it.
Good luck
det-ser92 is offline   Reply With Quote
Old 05-02-2008, 01:54 PM   #6 (permalink)
Nyc Sr20PowerD
Trader Rating: 15 (94%)
make sure the com ports match
Project Shift_Rebirth
Nyc Sr20PowerD is offline   Reply With Quote
