you forgot to reconnect the handle cable that actually pulls the latch. you can try the thieves way of opening with a coathanger inside the outer panel and try to snag the cable to trip the latch. but yeah, you forgot to put it back together right. good luck.
1997 200sx SE-R
1999 BMW Z3 Roadster
see the blue thing? the rod might not be in that. if its not, lifting the outside handle will do nothing. when u lift the handle, the rod pushes down on the blue thing, which is connected to a lever of sorts, and pops the door open
