Old 04-30-2008, 08:20 PM   #1 (permalink)
kineone2010
Need help with unknown SR20
I own 98 240sx, just picked up a sr20 motor for next to nothing. actualy more like nothing from my boss, long story, I know its from japan, RWD due to mounts, exh manifold, dist. hole and water inlet and out lets. It has no intake, harness, or dist.. I would like to tear down and take my time rebuilding this motor to relpace my KA24de. Problem is I have no idea what I have other than it is a SR20 and where to get the parts that I need. It has a silver v/c cover, stamped SR20 on the rear of the block follwed by some numbers and an alpha. I realy need help properly identifieng.
I have been told that I can use my exsisting harness, ecu, dist, and intake but how can that be and is it true? ANY and ALL help would be greatly appreaciteted. I can take pics of engine if that would help anyone help me. Thanks!!!!!
kineone2010 is offline   Reply With Quote
Old 04-30-2008, 08:47 PM   #2 (permalink)
WingmanSR20
MECP Master Installer
WingmanSR20's Avatar
post up that stamped number. there is also a thread on here you can find through searching that tells you what codes go to what engines.
1997 200sx SE-R
1999 BMW Z3 Roadster
Old 05-01-2008, 07:17 AM   #3 (permalink)
NissanSpeed01
sounds like a non tubro SR20DE RWD
NissanSpeed01 is offline   Reply With Quote
