Old 05-01-2008, 11:17 PM   #1 (permalink)
96SERTurbo
Clutch Options for Turbo Car
I am currently running an ACT heavy duty pp and street clutch. The setup has been on the car for ~27k miles, and now it is slipping badly. It started to slip about a month ago, and under 7 psi it will slip about 50% of the time. My car puts down ~255 hp. I know puck clutches are harsh engagement and harsh on the drive line; all us turbo guys know the problems with 3rd gear. Thus, minimizing drive line shock is a must. I have heard the Xtreme ACT pp has problems with engagement. ACT rates the street disc and Xtreme pp at 308 lb/lbs of clamping. My current setup is rated at ~230 ft/lbs. Does anyone know of other reliable options or have feedback to share?
96SERTurbo is offline   Reply With Quote
Old 05-01-2008, 11:33 PM   #2 (permalink)
twistedmindz
The champ is here
Trader Rating: 2 (75%)
competiton clutch ironman series great clutch hold power and soft pedal
Buy Build Blow up Start all over again
twistedmindz is offline   Reply With Quote
Old 05-01-2008, 11:39 PM   #3 (permalink)
96SERTurbo
Got a link or any other information to base your recommendation on?
Old 05-01-2008, 11:45 PM   #4 (permalink)
twistedmindz
The champ is here
http://www.competitionclutch.com/dsp...hp?vinvid=1424
Old 05-01-2008, 11:53 PM   #5 (permalink)
96SERTurbo
I browsed their site. They seem like they have some good stuff, but I have never heard of anyone praising them. I would like to avoid a puck clutch; this car is my daily driver.
Old 05-02-2008, 10:20 AM   #6 (permalink)
gtlaw
SE-R Newbie 4-life
my car has a CC clutch I'm not sure what one it is, but it is a 6 puck so its either an ironman or a stage 4. its HORRIBLE!!! the pedal engagement is like a light switch the pedal is extremely stiff, and worst of all its broken third twice. needless to say I'm switching to a exedy stage 1 it may end up slipping, but I would rather that than losing third again
gtlaw is offline   Reply With Quote
Old 05-02-2008, 10:58 AM   #7 (permalink)
twistedmindz
The champ is here
i have a fully built b13 the iron man clutch was the only clutch that held the power for me and my pedal is soft as hell
Old 05-02-2008, 12:12 PM   #8 (permalink)
NismoSER
VE powered on 12/9/07 :-)
NismoSER's Avatar
Trader Rating: 16 (100%)
I'd say swap your street disc out for ACT's sprung hub 6 puck. I ran that in my SE-R when it was turbo with the heavy duty pressure plate. The engagement was actually smooth in comparison to the Clutchnet that I had previously.
I had the same setup as you (ACT HD PP + street disc) but it started slipping @ 13psi on my T25 with the S4 cams. The puck held beautifully. YMMV.
Chris
'91 VVL-powered SE-R
'04 G35 6MT
