Old 05-02-2008, 04:08 PM   #1 (permalink)
coco42388
in ur fridge eatn ur food
cooling system is messed up somehow
ok before i go on i will say that my water pump is GOOD and the thermostat is GOOD. (tested in a pan of hot water with a thermometer and opened at 170*). now, when the car is running and is at temperature, it will cause the radiator hoses to expand and when the car is driving or stopped and is given gas, the temperature gauge will fall to below normal temp and when driving it will drop to C. can someone help me with this? there is no air in the system. has been redone several times....
______________________
1997 Nissan 200sx SE-R
http://img231.imageshack.us/img231/2...5sz4oy6.th.jpg
coco42388 is offline   Reply With Quote
Old 05-02-2008, 04:58 PM   #2 (permalink)
Nitelife
Nitelife's Avatar
Trader Rating: 15 (100%)
Check your ECU for codes, this is probably a bad coolant temp. sensor. Any drivability issues?
Old 05-02-2008, 05:13 PM   #3 (permalink)
coco42388
no driving issues. where is that located? i can find one on the FSM.
Old 05-02-2008, 05:33 PM   #4 (permalink)
Nitelife
Nitelife's Avatar
It's on the left-side of the intake manifold, near the oil filter and AAC.
Old 05-02-2008, 05:44 PM   #5 (permalink)
coco42388
[IMG][/IMG]
this thing? to the left...
Old 05-02-2008, 11:42 PM   #6 (permalink)
Nitelife
Nitelife's Avatar
Yes. The two prong one sends the signal to the ECU. What car is this on?
Old 05-03-2008, 12:38 AM   #7 (permalink)
PhorB13
SR20DEviant
Trader Rating: 20 (100%)
I had that issue too. I was actually noticing the temp sensor DROPPING to C while I was driving and never go passed the middle of the gauge. Check your coolant.
Originally Posted by Serban View Post
1991 SE-R -- Hot Shot intake w/ Pop charger, Megan cat-back exhaust, SSAC headers, JWT S4 cams, 2000 SE disc, ACT HD pressure plate, B&M shifter, ADV22 brakes w/ SS lines, FSTB & RSTB, ES sway bar bushings F/R, & Prothanes. Boost soon to follow
PhorB13 is offline   Reply With Quote
Old 05-03-2008, 12:50 AM   #8 (permalink)
jer_760
Broke Ass
jer_760's Avatar
It might just be the sensor for the gauge, the one on the right which is the single wire. Mine is loose and my guage is off because of it, sometimes the gauge will jump around also. Go check that plug to see if it is loosely connected to the metal prong/tab.
95 200sx
sr20ve
Old 05-03-2008, 01:44 PM   #9 (permalink)
coco42388
i disconnected and re connected the plug and it is running fine now. and i dont know if my hoses should have as much pressure on them as they do i cant really explain. i mean, they don't look like they will explode or anything. and my water pump and thermostat are both good. i guess if it blows it blows and i'll go from there. thanks for the input...
