Old 05-03-2008, 03:48 PM   #1 (permalink)
sohcvtec06
b14 tranny question
i have a 94 b13 and plan to swap in a SR. would a b14 tranny work in my b13? i imagine i would have to use the b14 axles. but is that it?
sohcvtec06 is offline   Reply With Quote
Old 05-03-2008, 03:53 PM   #2 (permalink)
swiss
swiss's Avatar
Trader Rating: 20 (100%)
The early B14 transmissions are pretty much identical. They have a redesigned 5th gear that isn't as likely to develop popout, and it has an extra sensor on the front of the bellhousing that you don't need, but aside from that they are the same. Just be careful because the late B14 1998-1999 trannys are non-LSD.
Old 05-03-2008, 03:54 PM   #3 (permalink)
jer_760
Broke Ass
jer_760's Avatar
Yes the b14 tranny will be fine, and you can use b13 or b14 axles as long as they are lsd and for an sr20 of course. Also, the b14 tranny will have an electronic speed sensor, so you will have to use one from a b13.
95 200sx
sr20ve
Old 05-03-2008, 03:56 PM   #4 (permalink)
jer_760
Broke Ass
jer_760's Avatar
I thought the 94 b13's had the crank position sensor like the b14's?
Old 05-03-2008, 04:00 PM   #5 (permalink)
swiss
swiss's Avatar
You're probably right, I didn't think about the lowport B13s.
Old 05-03-2008, 11:42 PM   #6 (permalink)
sohcvtec06
thanks you guys. i was posotive it would work, just hadda make sure. installing a b15 transmission would take a little more work
