Old 05-04-2008, 04:59 PM   #1 (permalink)
jagy
sr20
Low compression after cams install
Hi, ive installed S4 cams about 2 weeks ago. After 10mins. of cams install we have tested cylinder compression. 12bar everywhere. After a week of break in the cams, we have tested compression again - 10 bar on all four. Anyone know whats the problem? Manual says 12.75 standart, 10.78 minimum.
PS: Its JDM 10:1 DE, stock ECU. It was on 16° for a week and change it to 15° as JWT recomend. Running 100octan fuel (93 RON in USA?).
››› My Sunny 2.0 GTi JWT S4 cams - JWT Popcharger - Calum Basic ECU
WTB: HotShot CAI for highport (used or new)
jagy is offline   Reply With Quote
Old 05-04-2008, 08:48 PM   #2 (permalink)
Nyc Sr20PowerD
Trader Rating: 15 (94%)
i do know bigger cams lower your compression, but u did state that u did a compression test right after, and then 1 week after. im not 100% sure what would cause that.
do a leak down test to single out the problem
Project Shift_Rebirth
Nyc Sr20PowerD is offline   Reply With Quote
Old 05-05-2008, 12:07 AM   #3 (permalink)
jonwepa
Going on motor #3......
Trader Rating: 24 (100%)
Its normal. Nothing to worry about.
Old set-up: 91 se-r sr20de+T 13.04@110mph w/ a t25....
New set-up: same car, but with a gti-r motor and a gt28r. New LOWER times coming soon!
jonwepa is offline   Reply With Quote
Old 05-05-2008, 09:23 AM   #4 (permalink)
budgetNX
SR20DEEEEEP
thats exactly what i was going to say
http://www.myspace.com/beat_a_bitch
Originally Posted by Shawn B View Post
Then you get pissy, belligerant, and your panties get bunched up when someone, namely me, tries to actually help you with a couple of links?!?
Are you f*cking kidding me?!?
You sir, are an unmitigated selfish, egocentric, self-absorbed, DOUCHEBAG and can go f*ck yourself.
Old 05-07-2008, 02:51 PM   #5 (permalink)
jagy
sr20
Looks like you know, what youre talking about. Thanks guys.
