Originally Posted by CTGreen98200SX
Well, the car itself is reputable, it's "Joes97TurboSE-R"'s car... It's a very very clean b14, but the ECU wiring I want to take the time to cleanup while I wait for my clutch/flywheel to arrive.
I think it has a 300zx MAF becasue it is a Nissan MAF, but deff not the stock one, and it has 64# injectors he said. I know the car needs a tune.
I'm guessing this is one of the cars Jay Haas setup? JWT ecu programmed for MSD 72lbers@3 bar and a Z32 maf, but using a Z32 maf with motron 64lb injectors at 4 bar? Then running an e-manage blue on top to tune?
If it was me personally I would do what Eric is recommending, but I realize thats not for everybody.
If the car isn't running correctly or needs tuning you've got three options (and really which one you go with should be what your comfortable with or the shop that is going to work on the car is comfortable with)-
1-Learn how to use the e-manage blue and fix any wiring problems.
2-Repair or replace the harness (and if its been hacked up, its often easier just to replace it), change the setup to match the JWT programming, sell the blue.
3-Repair or replace the harness, use a RT and tune for the current setup, sell the blue/JWT.
If your not really interested in developing a tune for the car option 2 is the easiest. I would start by calling JWT and finding out if the current program on your ecu is their most current 72lb/Z32 maf program, and if it isn't have your ecu updated.
On option 3, I think there are a couple of guys up your way already doing this (ask Erick in CT).
