Old 05-07-2008, 12:42 AM   #1 (permalink)
SR20WhoKnew
IPR?!
Well I was talking to my friend how has an IS300 and he was telling me he
put an IPR on his car. He says you attach it to your fuel line and intake
and it "suppose" to make your car run smoother and save you gas. Anyone
heard of this? And does it really do what my friend described? Thanks
98' 200sx SE-R
- JWT Pop Charger
- High Port Cam
- Gen 1 HS header
- 2" Stromung cat-back exhaust
AutomaticJAIL !
SR20WhoKnew is offline   Reply With Quote
Old 05-07-2008, 09:54 AM   #2 (permalink)
swiss
swiss's Avatar
Trader Rating: 20 (100%)
FPR? Fuel pressure regulator kind of sounds like what you're describing, though I wouldn't use one in an attempt to save gas.
Old 05-07-2008, 03:07 PM   #3 (permalink)
WingmanSR20
MECP Master Installer
WingmanSR20's Avatar
x2. Not sure what an "IPR" would be...
1997 200sx SE-R
1999 BMW Z3 Roadster
Old 05-07-2008, 03:12 PM   #4 (permalink)
chriscar
merely a flesh wound
chriscar's Avatar
Trader Rating: 96 (100%)
Inline pressure regulator?
Old 05-07-2008, 03:36 PM   #5 (permalink)
WingmanSR20
From what I know, an inline pressure regulator simply makes sure you have constant fuel pressure. It's used in small engine applications frequently to ensure that, even though the fuel from the tank is erratic in pressure due to constant movement, the pressure going to the actual delivery system (carbs in most cases) is constant to keep RPMs stable and not have your ATV rip your arms out of your sockets.
I don't see how adding an IPR (if this is truly what he's referring to) would change anything seeing as it does the same function as our FPRs.
