Old 05-08-2008, 12:13 PM   #1 (permalink)
dmndd26
help needed
i have a 97 200sx and im doing the sr20 swap i was wondering if an obd1 sr20 would work and what different i would need like would the 93 motor mounts work and the wiring harness? what ecu is the best to get ffor a regular sr20 is the g20 ecu differnt then an se-r? can i use the ga16 axles or do i need to get different ones. by theway im going fro ga16 to sr20, i just got the ga16 out. do i need special mounts or will the sr20 ones fit? what else do i need to know to do the swap? thanks
dmndd26 is offline   Reply With Quote
