Old 05-14-2008, 04:28 PM   #1 (permalink)
jonwepa
Going on motor #3......
Trader Rating: 24 (100%)
what to do when flywheel bolts break!!
Well after dropping my tranny, I go to loosen the flywheel bolts and they don't move. Long story short 3 came out and the other 4 brok
e. Somebody help me out here!
Old set-up: 91 se-r sr20de+T 13.04@110mph w/ a t25....
New set-up: same car, but with a gti-r motor and a gt28r. New LOWER times coming soon!
jonwepa is online now   Reply With Quote
Old 05-14-2008, 04:48 PM   #2 (permalink)
Alex_se_r
I had the opposite happen to my RR motor, The flywheel bolts got loose and screwed up my threads and now I need a new crank and Flywheel! I'm thinking that's what your'e gna have to do.
Alex_se_r is offline   Reply With Quote
Old 05-14-2008, 07:08 PM   #3 (permalink)
jonwepa
I do have 4 bolts that still bolt up and the other three I am drilling holes in and am going to try and back them out. I think I'll manage without changing cranks!
Although worst case I do have a extra motor laying around were I could grab a crank if needed, its old but with some cleaning and new bearing's it will be fine.
Old 05-15-2008, 01:39 AM   #4 (permalink)
Brian47590
Nissan Tuner
Alex, did you strip out the threads on the crank, cause an easy fix to stripping is to drill out the stripped threads with a slightly larger bit and then rethread it with tap and dye set. Although they are pricey.
Jon, you're on the right track, drill a hole in the bolt that's left and get a screw and bolt extracter kit. They are fairly cheap and simple. They have reverse threads so that when the bit goes in and tightens it backs out the stuck bolt. Also use some PB Blaster or some kind of chemical to destroy the rust, assuming that is your problem.
First car: '90 240sx SE (stock) (still own)
Second car: '92 Honda Accord (2.5" exhaust) (5 mph flip into ditch trying to powerslide in gravel; Junkyard)
Third car: '98 240sx SE (stock) (still own)
Fourth car: '01 Sentra SE (stock) (just bought; $400)
Years of driving to cars owned ratio: 1.1
Brian47590 is offline   Reply With Quote
