Oil CApacity when changing - SR20 Forum
Old 04-16-2009, 07:17 PM   #1 (permalink)
Feedback Score: 4 reviews
hey guys, it has been quite awhile since I've owned an SR. Changing my recent 98 SE awhile ago. I put 3 quarts in there. I don't have the manual so just shot in the dark. I recalled the manual indicated 3 5/8...something. So, is that equate to about 3 1/2 quarts??
Where are you hurting today?
blkbird is offline   Reply With Quote
Old 04-16-2009, 07:29 PM   #2 (permalink)
Feedback Score: 5 reviews
I think I usually end up dumping 4 in mine.
Why don't you just add a little bit and check?
Old 04-17-2009, 08:27 AM   #3 (permalink)
I've check like about 5 times, I put 3 qts. in it, it went over the H mark. The dipstick on mine is a biatch. I bend to the curve of the metal pipe and between the coolant and aC line.
Old 04-17-2009, 04:10 PM   #4 (permalink)
Nismo King
Feedback Score: 8 reviews
IIRC its 3.85 quarts with a filter... so just about 4 quarts...
ser91 is offline   Reply With Quote
Old 04-17-2009, 07:22 PM   #5 (permalink)
thank you, that is what I need to know.
Old 04-18-2009, 08:46 PM   #6 (permalink)
apparently it is common for the sr20's to 'hide' some oil when changing it. I only got 3 liters in before it was toppped up and it stayed steadly for two months and then I had to add about a 1/4 liter.
coors75 is offline   Reply With Quote
Old 04-18-2009, 09:18 PM   #7 (permalink)
my change yesterday was exactly what Coors topped off. I put three quarts in it, man, it when over the H and around the top bend of the dip stick
Old 04-19-2009, 08:31 PM   #8 (permalink)
After adding the oil you need to crank the engine to let X amount of oil go into the new filter again and then shut it down and wait for a little while before checking for the oil level again. It should hold just under 4 qts.
91 Nissan 300ZX TT Slicktop
97 Nissan 200SX SE-R
92 Mitsubishi 3000GT VR-4, Sold!
89 Mazda RX-7 Vert. TII, Sold!
92 Acura Integra, Blown!
IR655 is offline   Reply With Quote
Old 04-30-2009, 06:38 AM   #9 (permalink)
Hello Newman...
Feedback Score: 14 reviews
3 5/8 Quarts of 5W-30. 3.625 if you want to get technical. That INCLUDES the filter. No more, no less.
95 SE-R turbo build
Do you have the parts I need? Click HERE
As always, post pics or DIE!
Flounder is offline   Reply With Quote
Old 01-26-2012, 01:48 AM   #10 (permalink)
... same issue I had today with my '95 SE-R... put in about 3 litres and ran the car for a few minutes. Turned it off and waited a couple mins to check the level and it was over the full (over the "H" mark by about 1/4").
I double checked my owner's manual and it says 3.4L when changing the oil and filter. Should I drain some out to get the level on the dipstick to the proper full level??
Yaaaaaah weeeeee vroom vroom!
JCheong04 is offline   Reply With Quote
