pilot bearing or bushing? *pics* - SR20 Forum
post #1 of 29 (permalink) Old 05-18-2009, 03:40 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I needed a new pilot bearing for the engine i'm dropping into the se-r (was an auto) so i went to the parts store.
they gave me a pilot bushing.
Is this right? Aren't bushings too old school, specially since this engine revs kinda high?
bad motor:
new pilot bushing for comparo:
replacement motor:
bushing by replacement motor (too big?):
rubenzzz is offline
post #2 of 29 (permalink) Old 05-18-2009, 04:23 PM
eric96ser's Avatar
Quoted: 0 Post(s)
Feedback Score: 29 reviews
You don't need it. The input shaft does not touch the crank.
The community is here.
eric96ser is offline
post #3 of 29 (permalink) Old 05-18-2009, 04:50 PM
Trial 'n Error Automotive
Quoted: 0 Post(s)
On the motor you are swapping in, was it an autonmatic.
Our cars only come with pilot bushings.
If that engine came from an automatic transmission car you need to remove that end piece on the crank to install the bushing.
-Wes
Working with Gspec. Saving my beans so i can fly to Cali and chill with The Greg man.
White '91 Se-r: Burns oil, Rear quarter crushed in, For Sale $800.00 obo.
novadose914 is offline
post #4 of 29 (permalink) Old 05-18-2009, 05:18 PM
Quoted: 0 Post(s)
Feedback Score: 5 reviews
Yeah, you have to remove that old one.
I drilled and tapped it in two places and used a crank pulley puller to remove it. They make removers, but I didn't have one.
People told me I didn't need to do it, but if nissan put it there, I'm going to put it there too.
skcusloa is offline
post #5 of 29 (permalink) Old 05-18-2009, 05:24 PM
Weekend Warrior
Quoted: 0 Post(s)
Feedback Score: 60 reviews
^I'm hearing you need it and I'm hearing you don't. I have a UK motor that came out of a auto car. I'm about to take the flywheel off and put my lightweight flywheel and ACT clutch kit on. What's up with this bushing, or should it be called a spacer?
Bend But Don't Break
MR-4Door-SR20DET is offline
post #6 of 29 (permalink) Old 05-18-2009, 05:28 PM
eric96ser's Avatar
Quoted: 0 Post(s)
-Wes
Again, the input shaft on the transmission does not extend that far to even touch the bushing/bearing, so it's useless.
post #7 of 29 (permalink) Old 05-19-2009, 12:50 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
yeah i noticed the same thing. the input shat looked like it would not extend far enough in to reach the pilot bushing. hmmm... i guess thats one less thing to deal with.
rubenzzz is offline
post #8 of 29 (permalink) Old 05-19-2009, 03:01 PM
Quoted: 0 Post(s)
Some Autozones have a loan-a-tool slide hammer with an attachment that fits in and behind the pilot bushing. Then as you tighten the slide hammer onto the tool it spreads the too, so it hooks behind. Then you just you slide the weight and it pulls the pilot bushing out. It's an awesome tool.
needMOmoney is offline
post #9 of 29 (permalink) Old 05-20-2009, 12:45 AM
S12 NUT
Quoted: 0 Post(s)
A lot of those pullers won't remove the auto bushing...
But, what I've found that works well, is take a pipe that's the same size at the hole in the bushing, insert it only as far as the bushing is thick, then just push down. It'll just pop that sucker right out.
I had to do the same on my RWD SR20DE when I got it, as it was an auto.
I tried pulling, cutting, cursing, nothing seemed to work. lol
seishuku is offline
post #10 of 29 (permalink) Old 05-20-2009, 01:18 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
i bought a new oem-style clutch, but wondered how the clutch alignment tool would properly sit if there was no pilot bushing? wouldn't it be too loose and might cause an improper clutch fitment?
rubenzzz is offline
post #11 of 29 (permalink) Old 05-21-2009, 04:51 PM
Not a Newbie
Quoted: 0 Post(s)
Yes, the alignment tool on my GA16 didnt work well, and the bushing was not needed for a 97 (and wouldn't fit anyway, looks like Nissan only rough machined the hole, didn't do the final size it for the bushing)
From what i found out its in the kit for the older E16 engines/Transmissions that use the same clutch.
I guess its the same for the SR20, needed for the older engine/trans
I cut the end off the alignment tool and it kind of worked then.
1997 SE-R 5 sp yea !!!
2003 Pathfinder SE 4WD
1997 Sentra GXE Sold !!
Ex- 2001 Sunny N16 RHD (N16 Nissan Bluebird Sylphy)
Ianh is offline
post #12 of 29 (permalink) Old 06-08-2009, 06:58 PM
Wait, why did I buy this?
Quoted: 0 Post(s)
I've heard of a cool way to remove pilot bushings:
Take a pipe/rod that fits pretty perfectly within the bushing. Pack the bushing with grease. Bang on the rod, and the bushing is supposed to come right out.
I used a jigsaw then a hacksaw blade, which took forever. Wish I'd heard of that ^ method.
1966 VW Bug (Sold)
1979 GMC Sierra Diesel (Sold and good riddance)
1990 Mazda Miata (Immaculate and stored in my barn)
1992 Sentra SE-R (Back from the dead, 35 mpg, and faster than all of the above)
1980 Honda XL185s, 80 mpg!
Petelite is offline
post #13 of 29 (permalink) Old 06-09-2009, 11:18 AM
Not a Newbie
Quoted: 0 Post(s)
To answer your question on the bushing being "old School" remember the only time there is rotation in the bushing is when the clutch is depressed, so its a low use low load situation. If you get a transmission that has the journal on the input shaft, install the bushing.
Ianh is offline
post #14 of 29 (permalink) Old 06-10-2009, 01:24 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
that never works. all it accomplishes is to make a big greasy mess. The best way i've discovered is using slide-hammer with the proper attachment that you can rent for free from autozone.
rubenzzz is offline
post #15 of 29 (permalink) Old 06-10-2009, 01:32 PM
Not a Newbie
Quoted: 0 Post(s)
I haven't tried it but the principle is sound so long as the rod is a snug fit in the old bushing. The hydraulic pressure will force the bushing out.
Ianh is offline
post #16 of 29 (permalink) Old 08-17-2009, 10:44 AM
Weekend Warrior
Quoted: 0 Post(s)
^So which one guys? One says yes and the other says no. I'm at a stopping point on my build right now. I was going to put the flywheel and clutch on my UK 10.1 motor but this bearing is keeping me from using my pilot bearing that came with the clutch kit.
^Motor from AUTO
^Motor from MANUAL - Spare block
post #17 of 29 (permalink) Old 08-17-2009, 12:22 PM
eric96ser's Avatar
Quoted: 0 Post(s)
Throw the bushing in the trash.
post #18 of 29 (permalink) Old 08-17-2009, 02:31 PM
Weekend Warrior
Quoted: 0 Post(s)
^Lol. Ok Eric, I want use it. Should I still take that other bearing off the motor?
post #19 of 29 (permalink) Old 08-17-2009, 04:26 PM
Not a Newbie
Quoted: 0 Post(s)
Originally Posted by MR-4Door-SR20DET View Post
^Lol. Ok Eric, I want use it. Shouldn I still take that other bearing off the motor?
Can we have a Picture of your input shaft please ??
Ianh is offline
post #20 of 29 (permalink) Old 08-17-2009, 04:37 PM
Rebuilding
Quoted: 0 Post(s)
Feedback Score: 31 reviews
i have an automatic motor and ive never used one. Been 3years no issues.
1997 200SX SE-R - 280whp & 264tq
"Shut the fu*k up and sit down"
2dr_sentra is offline
  SR20 Forum > Main Forums > General SR20
User Tag List
