S13 Dies at 2k rpm - SR20 Forum
Old 05-12-2012, 10:46 AM   #1 (permalink)
S13 Dies at 2k rpm
Tested out my S13 powered Deman Sr7 after successful fall tests and the engine dies when it hits 2000 rpm when moving. It revs fine when in neutral. Ecu was showing a CAS issue but I tested CAS wire 1 (.1 to 5 v) and 2 ( .1 to 2.5 volts) which I believe is ok.
I just tested it again and the ecu us showing no error codes
Thoughts anyone?? Need help urgently
gllongdrink is offline   Reply With Quote
Old 05-14-2012, 02:11 PM   #2 (permalink)
Or does anyone know the ecu logic for invoking a fuel cutoff?
Old 06-02-2012, 05:59 PM   #3 (permalink)
Problem solved!! Disconnected ecu speed sensor lead from my new auto meter speedo and the engine rocks !!
Car is freeken fast, s13 in a 1200 pound car
