Old 09-30-2003, 02:48 AM   #281 (permalink)
SE-R_Tj
This should be a sticky!!! I have few weight reduction, so I'm gonna weight my car this weekend.
Nitrous with progressive controller, MSD digital 6, s4 cams, fidanza flywheel, UR pulley, p/s wliminator kit, B&M SS, 2.5 side exhaust, Weld rims, Hoosiers slicks, GC coilovers, eibach springs, Sparco seats, harness, Steering wheel, skinnies, Custom 6 puck clutch, lexan windows, Roll bar, aluminium dash, Kaminari body kit,
91 SE-R "2070 lbs"
SE-R_Tj is offline   Reply With Quote
Old 09-30-2003, 11:06 AM   #282 (permalink)
SmoothDaddyFig
NISSAN SOLDIER
I have done like 10 other weight reduction things but my PC is broken so I cant show any pics yet.
Im aiming for a 1850lb daily driver.
Jonathan
93 G20 "Im cruising tonight"
Old 09-30-2003, 04:41 PM   #283 (permalink)
sr20andafalcon
banned
way to go fig!im getting there,u guys try drilling some holes in some stuff that isent gonna leak.if u have stock battery box drill that thing out it dont take much to hold the battery up.
sr20andafalcon is offline   Reply With Quote
Old 09-30-2003, 06:44 PM   #284 (permalink)
sr20andafalcon
banned
got a question for u fig i have took the following off tow hooks,exhaust shields,metal brace in the trunk that supports the muffler hanger,jack holder,all carprt in the back,drilled holes in stuff in the back such as hinges and bracing,ac condensor and compressor,radiator over flow,washer fluid holder and lines,all sound deadner and firewall blanket,brace under steering wheel,all the emissions crap,and a few other brackets and bolts,how much do u think i have shaved off? just ballpark would be nice.is there any other big stuff i cant remove, back seat as i have a son and i want to keep and the interior for now.do u think this is enough to show up at the track.thanks to all that have posted on this thred i have really used it
Old 09-30-2003, 08:23 PM   #285 (permalink)
AaroNX
There is another brace behind the glove box that you can remove.
http://phatboyaudioonline.com/
1993 NX2000-5SPD SWAP, 2120lbs. JDM Motor, Calumsult Realtime ECU, Brian Crower STG 3 cams, CP XTP 9.2:1 pistons, NX DP-100 shot, Prothane Mounts, ACT Xtreme/street disc, PR CAI with JWT POP, SSAC with 2.5" downpipe, Dynomax 3" muffler, Outlaw Intake Spacers, OEM wires with ngk plugs, UR Pulleys, Walbro 190, ST springs with KYB's, Xstatic Batcap, Axis maglites
Old 09-30-2003, 11:50 PM   #286 (permalink)
99SE-L
I removed the battery tray completely. There's a pic here.
99SE-L is offline   Reply With Quote
Old 10-01-2003, 01:54 PM   #287 (permalink)
sr20andafalcon
banned
hum i know what ill be doing tonight
Old 10-01-2003, 02:35 PM   #288 (permalink)
SmoothDaddyFig
NISSAN SOLDIER
I use a lawnmower battery so I shortened my tray.
Falcon,
Every SE-R varies in weight so its really hard to say how much your car would weigh.
You can always take off your trunk and hood supports.
Your trunk hinges would go as well.
Lose BOTH your hood and trunk LATCHES.
Use aluminum hood pins on the hood.
Use ZIP TIES whenever possible.
Cut off the lower part of your dash.
Cut off the lower part of you door panels.
Old 10-01-2003, 02:36 PM   #289 (permalink)
SmoothDaddyFig
NISSAN SOLDIER
If You Dont Have A Dremmel,
You're Not Losing Weight.
Old 10-01-2003, 09:55 PM   #290 (permalink)
sr20andafalcon
banned
ty i have some more work to do i want to get to a wieghing station soon
Old 10-02-2003, 10:07 PM   #291 (permalink)
sr20andafalcon
banned
hey lets dont let this thread die!!!
Old 10-02-2003, 10:09 PM   #292 (permalink)
sr20andafalcon
banned
hey fig what do u do with a dremel, i mean i got a drill and sawzall but what cant i do with this stuff
Old 10-02-2003, 10:09 PM   #293 (permalink)
98SERwTricks
SR20VE or a T28? I dunno!
IByourcarflexeslikeawetnoodle
Sam Bass / 1998 200SX SE-R
Atlanta, Georgia
98SERwTricks is offline   Reply With Quote
Old 10-03-2003, 01:52 PM   #294 (permalink)
sr20andafalcon
banned
no if u take nothing from the frame structure are any bracing for the frame it will not flex a bit,especially if u have a rstb are a fstb or sway bars
Old 10-03-2003, 04:27 PM   #295 (permalink)
SmoothDaddyFig
NISSAN SOLDIER
LOL............... thats what everyone thinks.
But thats so not true.
Falcon,
The dremel will let you cut in tight small places. And its by far more accurate then a SAWZALL. PLUS, the SAWZALL blade cant go where a little cutting can.
Old 10-03-2003, 06:13 PM   #296 (permalink)
Nissanluver
Hell yea, it's back!!!
Nissanluver is offline   Reply With Quote
Old 10-03-2003, 10:34 PM   #297 (permalink)
sr20andafalcon
banned
hey fig do u have a pic of under youre hood?what all have u took out under it
Old 10-03-2003, 11:21 PM   #298 (permalink)
AztekSE-R
Shift_日産
OMG what have i done
This thread is huge
1996 Nissan 200SX SE-R
クリストファー
•AT-MT B13-LSD swap •JWT P/P •2000SE Clutch Disc •Cusco FSTB •Hyperco Gen2 •Unorthodox 4 Pulley Set •HP Racing Header •Rota 16x7 Circuit 8 w/ BFGs •12Lbs.Flywheel •Injen CAI •Stillen POP Charger •B&M Short Shifter •91 Cam •Prothane Mounts •Magnaflow Muffler •Taylor 10mm Wires •Carbon Fiber Hood •Erebuni Body Kit •Black Healights w/ Amber corners •Redline MT90
AztekSE-R is offline   Reply With Quote
Old 10-04-2003, 12:20 AM   #299 (permalink)
blairellis
<>< Jesus is the Answer
blairellis's Avatar
see the first couple pages of this thread for pics of figgys engine and interior.
Blair
93 P10
Old 10-04-2003, 05:05 PM   #300 (permalink)
Mad200
another wieght reduction u can do is when u go drag racing go naked...shoes clothes maybe belt... ucan save at least 10 pounds!!!
Mad200 is offline   Reply With Quote
