Lets keep the comments low and make this just an Info Post on the things removed and weight....... Post up and ill add it to the list . This includes you figgy.
dash = 9lbs
side electric mirrors 4.5 lbs
side manual mirrors 4.2 lbs
plastic side molding 2 lbs
Sounddeadening material including tar and the rubber firewall blanket and steel brace under steering wheel 52lbs
reclining mechanism on SE-R seats 3lbs
A/C compressor including iron bracket and all lines and condenser 32lbs
Rear quarter windows 4.9 lbs
Front seats weigh 33 pounds each.
Back seat weighs 10.5 pounds.
Carpet weighs 9 pounds.
Spare tire well weighs 14.5 pounds.
Bumpers weigh 25 pounds each.
Bumper covers weigh 11.5 pounds each.
All the heat and a/c parts in the dash weigh 28 pounds.
The support rods for the trunk weigh 6 pounds.
Brace under dash = 5lbs
B13 SE-R wheels = 16.7 lbs!!
trunk hinges, 4 tow hooks, and muffler hinges and that came up to 13lbs
The side power mirrors weigh 2.5lbs
Non-powered side mirrors weigh 2.3lbs
All the sound deadening plus the steel bracket under the steering wheel, and the rubber firewall carpet weigh 48.2lbs
Sunroof (40 pounds)
Door Beams (10 pounds each)
Inner Door Skins - the metal (4 pounds)
Door Panels (20 pounds)
Front Windows and Guides (4 pounds)
Unused Wires from Harness (7 poounds)
Underside for Trunk Skin (4 pounds)
Rear Valence/Shelf and Trunk hinges (12 pounds)
Replaced Stock Hood with C/F (30 pounds)
Air Conditioning (40 pounds)
Power Steering (8 pounds)
Gutted Bumpers - still functional BTW!!
Front (8 pounds)
Rear (7 pounds)
Aftermarket (thicker) Front Sway bar (18 pounds)
Interior Sound Deadening material (50 pounds)
Front Seats (35 pounds each - replaced with CF one @ 10 pounds)
Rear Bench Seat (10 pounds)
All Seat Belts (10 pounds)
compressor weighs like 25, condensor 10, exchanger 5, bracket like 3 or 4 and the associtaed lines another 5 or so
on the B13 there is a heavy metal plate that sits above the door locking mechanism. It is inside the doors metal panel. Unbolt it and pull it out.
Maybe 1 or 2 pounds.
Lose all four TOW HOOKS.
Lose as many metal brackets that hold wires in place as you can and use plastic zip ties to keep them in place.
Look in the engine bay: Pull out all the fuses you dont need. e.i. A/C , Power steering. Then after you do that SAW off the extra plastic that was there to hold the fuse there in the first place.
Lose half your bumper. Like in my sig.
Keep your STOCK brakes!!!!
You will not need no damn NX brakes once you weigh 1900 lbs.
Take out your passenger side fan
once you take out the a/c.
Lose the passenger side mirror.
KEEP THE 80s alive!!!!
Lose that damn radio!!
Enjoy the hits from your valvetrain and your exhaust.
Im giving away too much. I gotta go!!!!
Front fender and splash gaurd 8 pounds.
Cut out hood and loose the latch and hinges 12 pounds
Wiring harness in dash, remove all unused wires and plugs, after you loose the dash 11 pounds
Misc. nuts,bolts,screws and hardware from gutting whole car 9 pounds
stock exhaust replaced with side exit 14 pounds (includes hangers not used)
1992 Super Black SE-R~ Totaled, parting out soon
1991 Super Black SE-R race car~ 1866 pounds for the moment.
1991 NX2000 Red~ Stock
figgster...seriously bro...i know theres more in that shell of yours that can come out
Blair
93 P10
for my nx, I was thinking about a "del-sol" style rear deck, or mr2 style. Flat, with a near vertical small window(read: plexi-glass) just behind the front seats. I bet there's 50lbs. in that conversion easy. Anyone know where to buy huge sheets of that special plexi-glass they make for cars that's super scratch resistant?
Well this is some stuff i want to remove. Ok here is the rules.
1. Its a daily driver, autox whore, and drag car.
2. I have to have all the seats and carpet and dash.
3. No cutting the wiring harness.
4. No cutting body panels
5. I need the water sprayers for the winshild for winter time.
Spare tire and Jack = ?????
A/C 32-40lbs
Smaller Battery + around 10lbs or so
so anything else that i could remove?
