View Poll Results: Is Redline 75W90 GL5+ Gear Oil Safe to use in an SR20 M/T?
Hell yea, that stuff cost you $11 a bottle! 1 25.00%
fu*k no, $44 or a new tranny, what's better? 3 75.00%
Voters: 4. You may not vote on this poll
Old 03-22-2004, 06:38 PM   #1 (permalink)
ビ十四番
Redline 75W90 GL5+ Hypoid Gear Oil
With the revival of the Redline thread, I wanted to know what you guys think about the oil I just put in my tranny...
This stuff is exactly like MT-90 except for the GL5 rating... I went to the only store in the city that carries redline stuff, and this was the closest thing to MT90 I could get... Should I change it or do you think I am OK? Still shifts pretty good.
-Simon
B14 200SX SE-R w/ Injen short-ram, 91 SE-R Intake cam, JUN Ultralight flywheel, ACT HD clutch and street disc, Greddy SP cat-back, strut bar from courtesy, and the legendary B14 hypercos/AGX combo.
^^wrecked atm
[UPDATE] wrecked. forever
ResidentWarui is offline   Reply With Quote
Old 03-22-2004, 07:08 PM   #2 (permalink)
Undecided
Re: Redline 75W90 GL5+ Hypoid Gear Oil
Not sure. I'm wondering along the same line. I bought Lucas 75w90 Synthetic thats desgined for High performance and LSD equipped trannys. It says its a replacement for GL5 and GL6.
97SE-R
1/8 8.6@ 85
R.I.P. John
97SE-R C2 is offline   Reply With Quote
Old 03-22-2004, 11:08 PM   #3 (permalink)
Enjoy the GTR Matt!
Trader Rating: 23 (100%)
I thought GL5 was very bad, as in eats the synchros and stuff.
Old 03-22-2004, 11:18 PM   #4 (permalink)
P10 Geek
The 75W90 is not safe on the Nissan synchros. It will shorten their life span drastically. MT-90 is specially formulated for GL-4 applications like the Nissan synchros.
IMO you should get the correct type and drain your tranny.
Brandon
'02 Maxima SE 6MT
'96 G20 (SOLD)
Old 03-22-2004, 11:27 PM   #5 (permalink)
The Super Mechanic
supercowboy's Avatar
What makes nissan syncros so special. They are made of brass
06 monaro cv8
91 ser 311whp@15psi
CT SUPERHERO
DO YOU KNOW WHO I AM!!! I THOUGHT SO!!!!
supercowboy is offline   Reply With Quote
Old 03-23-2004, 01:31 AM   #6 (permalink)
ビ十四番
I'm gonna call Courtesy, Mossy, and Redline tommorow and see what they say... I kinda don't wanna change the fluid again, but I guess I might have to. Maybe I could just refil the old oil bottles and try to return it
-Simon
^^wrecked atm
Old 03-23-2004, 02:47 AM   #7 (permalink)
GT2835R
Dont go cheap on something important. Especially since out trannys cant take that much abuse as it is.
Rey Uy
99 SE-Limited
Old 03-23-2004, 03:24 AM   #8 (permalink)
It "eats" the brass. Not a good thing.
Home of the low (Original) Mileage B13
1992 B13 SE-R - Original Owner. 66K
2004 Avante XD2 GT - DD
2000 Miata LS - Top Down Fun!
MY SIG PIC ------------> http://i34.photobucket.com/albums/d1...31/SE-REGT.jpg
Originally Posted by Octave236 View Post
Uh i believe your contridicting yourself. B13's are highport motors unless a lowport was swapped in.
CleanSE-R is offline   Reply With Quote
Old 03-23-2004, 09:49 AM   #9 (permalink)
woo dee woo
I just did some serious research and i had no idea that our transmissions could suffer damage from a GL-5 oil. When i had to replace my driveaxles back in september i topped off the tranny with some valvoline synthetic 75-90w i had laying around (which is GL-5). i just ordered some redline mt-90 and i will change it out as soon as i recieve it. on the redline site it says that GL-5 will reduce syncro life by half...no good. I wonder how much damage i did by topping off the tranny with GL-5 after the driveaxle swap. It's only been about 6 months.....but i beat on my car pretty bad.
NJse-r is offline   Reply With Quote
Old 03-23-2004, 10:05 AM   #10 (permalink)
Now accepting donations!!
El Gabito's Avatar
I thought mt-90 was 75w90...? It's just that it's GL-4, not 5.
My real name is Kyle
El Gabito is offline   Reply With Quote
Old 03-23-2004, 11:36 AM   #11 (permalink)
You're exactly right. MT-90 is 75w90.
miamimax95 is offline   Reply With Quote
Old 03-23-2004, 07:22 PM   #12 (permalink)
ビ十四番
The guy I talked to at Redline said the same thing that the guy reported on the Redline thread. Bottom line, although the GL5 75W90 doesn't eat Nissan synchros, it does have a friction agent in it that makes shifting harder. I know now to always go with MT-90!
Gonna go across the Golden Gate Bridge to get some MT-90 now.... Some times i don't know whether this forum is a curse or a blessing
jk, thanks for the input.
damn mackenzie...
-Simon
^^wrecked atm
Old 03-23-2004, 10:47 PM   #13 (permalink)
P10 Geek
I was not referring to MT90. He (ResidentWarui) stated he used 75W90 Redline Gear Oil. There is a difference.
Sorry I did not clarify which Redline 75W90 I was referring to.
Here:
THIS ONE IS BAD FOR NISSAN SYNCHROS (hard shifts, etc.)
75W90 Gear Oil - the preferred product in nearly all car and light truck differentials, both conventional and limited-slip. 75W90 is preferred for most racing applications. It contains friction modifier which is recommended for limited-slip units. 75W90 Gear Oil can be used in many transmissions and transaxles; however, other Red Line lubricants have better frictional properties for rapid synchronization. Exceeds API GL-5.
THIS IS THE CORRECT 75W90 TO USE
MT 90 - Manual Transmission/Transaxle Lubricant. A 75W90 GL-4 gear oil which is designed for manual transmissions which require 75W90, or 90 GL-4 gear oils or motor oils. Uses the same chemistry as MTL , but is a 90 WT in order to satisfy certain manufacturers which recommend SAE 90 GL-4 gear oils.
Brandon
'02 Maxima SE 6MT
'96 G20 (SOLD)
Old 03-23-2004, 10:48 PM   #14 (permalink)
P10 Geek
ACK! Double post!
Brandon
'02 Maxima SE 6MT
'96 G20 (SOLD)
Old 03-24-2004, 05:35 PM   #15 (permalink)
ビ十四番
Just put the MT-90 in... MUCH BETTER! Shifts into first easier than ever.
Oh yea, and for those of you who made the same mistake I did, don't try to save the old 75W90... In my case I had the GL5 stuff in for about 200 miles and figured I could re-bottle and sell it to some cheap guy for $5/ bottle. Anyways to make a long story short it ended in a huge disaster, big pool of tranny fluid on the floor.... Kinda hard to do this alone without a clean pan that will catch a lot of oil. That fluid really comes rushing out. Glad I didn't try this at home...
-Simon
^^wrecked atm
Powered by vBadvanced CMPS v3.1.0
Powered by vBulletin® Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
