Help! Loud clanking noise on engine... - SR20 Forum
post #1 of 14 (permalink) Old 10-29-2004, 11:30 AM Thread Starter
I run 17s
Quoted: 0 Post(s)
Feedback Score: 3 reviews
(Thread Starter)
I turned the car on this morning and i heard a loud clanking noise... Popped the hood and didnt see anything unusual but the noise sounds like its coming from the head. I checked belts around engine to find anything unusual. I took it for a drive and everything still runs fine. Still has power like it always had. So i took it for a short drive to let it warm up well. Checked under hood still making the loud clanking noise. It sounds like metal hitting metal sound. any info if this engine is done??
'00 Q45 32 valves 4 cams and a ishh load of gas!!!
'02 G20 Sport - 05 Maxima HID. AEM intake. R.I.P.
'92 SE-R - Bruised with a few bolt ons R.I.P
Viruz1 is offline
post #2 of 14 (permalink) Old 10-29-2004, 12:18 PM
Nitelife's Avatar
Quoted: 0 Post(s)
Feedback Score: 47 reviews
Uhhh...hopefully you didn't drive around too much. Just a possible scenario would be something loose clanking around under the valve cover, like, say a rocker arm or maybe a loose bolt.
Nitelife is offline
post #3 of 14 (permalink) Old 10-29-2004, 12:34 PM Thread Starter
I run 17s
Quoted: 0 Post(s)
(Thread Starter)
Could it be a bad timing chain or timing chain gauide or something like that. I drove it work which is about 3 miles.
Viruz1 is offline
post #4 of 14 (permalink) Old 10-29-2004, 12:39 PM
Built not bought
Quoted: 0 Post(s)
Feedback Score: 8 reviews
could be the beggining of a bearing that is about to be spun or the problem can be a loose bolt, or rocker arms stoppers, but u never *** i had a slight pitterpatter in my engine, and my shit spun 2 bearings on tuesday going home to pick up somthing in the middle of the southern state better check on it befor it is too late.
^^ BUILT BY BOLT^^^
Nyc Home of the greatest !!!!!!!!!!!!!
Nissanwulf is offline
post #5 of 14 (permalink) Old 10-29-2004, 12:45 PM Thread Starter
I run 17s
Quoted: 0 Post(s)
(Thread Starter)
crap now im shittin bricks! It just started overnight though. and i havent beat on the engine or anything. ill have to check my oil on my next break as well as the coolant fluid.
Viruz1 is offline
post #6 of 14 (permalink) Old 10-29-2004, 12:56 PM
Big Cheddar fan club
erick212's Avatar
Quoted: 0 Post(s)
Feedback Score: 7 reviews
Could be a bad lifter but that is more of a metal on metal tick than a clank. Sounds more like a rod bearing , you don't have to beat the engine for it to happen believe me I know.
06 Frontier
low post count=working on cars more than computers
SR20deep Ct.
erick212 is offline
post #7 of 14 (permalink) Old 10-29-2004, 01:09 PM
Built not bought
Quoted: 0 Post(s)
check your oil pan if it has any dents in it. dats all i can say
^^ BUILT BY BOLT^^^
post #8 of 14 (permalink) Old 10-29-2004, 01:39 PM
Monkey Power
Quoted: 0 Post(s)
Feedback Score: 6 reviews
if you start the car and remove one plug wire at a time you can find out if you have a bad bearing. when the plug wire is removed from the cylinder that has a problem the noise will go away.
94 se-r 342whp 300lbft @ 15psi
92 se-r sr20ve with N1 cams soon to turbo
http://www.cardomain.com/id/cortrim1
www.southern-shift.com
cortrim1 is offline
post #9 of 14 (permalink) Old 10-29-2004, 02:42 PM Thread Starter
I run 17s
Quoted: 0 Post(s)
(Thread Starter)
^^ Good tip, BTW bad bearings arent fixable or if they are, its not worth it since JDM engines are so cheap?
Will a compression test also show if the engine is still healthy maybe something else?
Viruz1 is offline
post #10 of 14 (permalink) Old 10-29-2004, 03:00 PM
Monkey Power
Quoted: 0 Post(s)
you can replace the rod bearings for about $30-50 but its hard to do with the motor in the car(not 100% sure it can be done with out removing the motor). A compression will tell if you have bad rings or a valve issue. A stethoscope could help you pin point the location of the noise.
cortrim1 is offline
post #11 of 14 (permalink) Old 10-29-2004, 03:02 PM
SR powered S13 coupe
McCoy's Avatar
Quoted: 0 Post(s)
Feedback Score: 78 reviews
Pull your valve cover and check. There was a post a while ago that sounded very similiar to this. The person had the timing chain guide break and was bouncing off the chain.
www.jgstools.com
www.nissanroadracing.com
McCoy is offline
post #12 of 14 (permalink) Old 10-29-2004, 03:45 PM
erick212's Avatar
Quoted: 0 Post(s)
1. not a good idea to do the bearings in the car(don't do it)
2. if the crank is mard at all it will need to be re-surfaced(or replaced)
3. buy a JDM motor and just swap then when you get a chance rebuild the motor that has the bearing problem. At that time you can set it up any way you want ie. turbo, high CR , or what ever.
Just my opinion, i have found it to be the easiest way for me. Lets hope it is just something simple and you have it fixed tonight.
06 Frontier
SR20deep Ct.
erick212 is offline
post #13 of 14 (permalink) Old 10-29-2004, 03:52 PM Thread Starter
I run 17s
Quoted: 0 Post(s)
(Thread Starter)
Ok i went to my friends shop and we figured the noise and the problem... Loose EGR plug on the exhaust manifold. LOL!
Viruz1 is offline
post #14 of 14 (permalink) Old 10-29-2004, 04:06 PM
Monkey Power
Quoted: 0 Post(s)
good at least it was nothing major.
cortrim1 is offline
  SR20 Forum > Main Forums > General SR20
User Tag List
