Does not come with a restrictor, I never ran one on my se-r, and never had any problems. Parts are in stock, and if you order today, it will go out Monday.
Question - is the oil pressure sensor thread on the SR20 the same as the one on the GA16? I'm assuming its around the same place on the engine. Or is that not where the kit tapes the engine for the oil feed?
You got me, but I would assume that the GA16 prolly has the same threading on the oil pressure sender. Since you have the motor, youll have to find out that info.
Could I get one of these with out the tee? I have already purchased one of his ^^ dist. blocks. I would like to just replace the tee with the block I have.
Thanks
Just use the part numbers for the other fittings, and find the size line you need. Those fittings are for a -3an line.
Do you guys have the oil line fittings for the T3 turbo?
http://www.cardomain.com/ride/849607
[i]1997 RED 200SX SE-R, BMW SIDE MIRRORS W/LIGHT, BLACK HALO HEADLIGHTS, STEALTH CORNERS, AGX ALL AROUND,/I]
That fitting looks like it would screw into the block, or at least you'd need a bspt adapter for it, still not sure what fitting goes on the other end.
