Go Back   SR20 Forum > Vendor Customer Support > GoFastDepot.com
Old 11-04-2005, 03:46 PM   #1 (permalink)
Trader Rating: 102 (100%)
Oil Cooler Kit
Hey guys, we put together an SR20 oil cooler kit..and here it is
Oil Cooler Kit with Braided Hose: $168.00
Oil Cooler Kit with Push-on Hose: $148
Serban is offline
Old 11-04-2005, 03:50 PM   #2 (permalink)
merely a flesh wound
chriscar's Avatar
You've got mail.
chriscar is offline
Old 11-04-2005, 04:14 PM   #3 (permalink)
oh so LAZY
Will's Avatar
would you sell just the oil filter piece? if so, how much?
Click for My Car Pics
White '92 NX2000 All Stock.
Will is offline
Old 11-04-2005, 04:26 PM   #4 (permalink)
$43.99 its currently not on the website yet.
Serban is offline
Old 11-05-2005, 06:44 PM   #5 (permalink)
All Things SR20
Trader Rating: 35 (100%)
This is awsome. Is there going to be a group buy? I'ld be down for it. Well, I'll take one no matter what is a few weeks.
Daniel2.0 is offline
Old 11-05-2005, 09:13 PM   #6 (permalink)
Trader Rating: -1 (0%)
At the risk of sounding like a NOOB asshat, I have a couple of questions:
1) On average, how much extra oil capacity does this afford you? 1/2 a quart? 3/4 qts?
2) Given the lack of space in the stock location of the oil filter, how for the love of god, do you fit that filter adapter in there?
3) Does it have instructions for the dumber crowd (such as myself) ?
4) Where would you RECOMEND mounting said hardware on an NX2K that's looking to have a Koyo rad. and HS/JGY IC shoved into the front end?
Thankyou and please drive through
92 NX2K Hardtop
Suspension, Intake, Header............it's slow, but it corners well
BIGBULS is offline
Old 11-05-2005, 09:32 PM   #7 (permalink)
Trader Rating: 53 (100%)
Bad-ass Serb, this will be on my list as I re-do my set-up.
SR20RACER is offline
Old 11-06-2005, 12:59 AM   #8 (permalink)
No soup for you
Trader Rating: 30 (100%)
Do you have the different thread adapters to allow for both highport and lowport?
John
B12 turbo madness
424 whp / 328 ft. lbs
2440 lbs. w/ a full tank
B14 VE Hotness
244 whp / 228 ft. lbs
Big John is offline
Old 11-07-2005, 11:42 AM   #9 (permalink)
1) On average, how much extra oil capacity does this afford you? ½ a quart? ¾ qts?
1. 1-1.5 extra quarts, the cooler alone holds about a quart.
2. It will be a tight fit, thats for sure.
3. No instructions, its quite easy, remove the oil filter, screw the sandwich plate in there, screw the filter on the plate, run the hoses to the cooler.
4. You've got some limited space, Maybe you can fit this cooler to the side in the wheel well behind the foglight. It might be a tough fit for you.
Serban is offline
Old 11-07-2005, 12:43 PM   #10 (permalink)
Metal Cutting Madman
Trader Rating: 47 (100%)
I really dont want to rain on your parade, but one thing you guys really need to consider is the pressure loss you will see with the oil cooler setup. Specifically the size of hose your using.
Our pumps put out a little less than 10 gpm (from what Ive been told) and you can see the pressure loss with this chart with 10 feet of distance using a given hose. Running -6an (which the top looks like) might be a bad thing in this case.
Can you guys do this with larger oil lines? Like -8 or -10 ?
PS: I got this from Ben Rockwell a while ago and just passing info on for you guys...
Originally Posted by Ben Rockwell via email
Here is a chart from Aeroquip on pressure loss. The chart shows psi drop for a 10 ft section of hose. The x-axis shows hose ID. Standard AN hose will have the lower ID value. This chart also shows loss values typical of a SAE 40 single grade oil at 100F. A 10W40 at 200F would have losses about 25% lower. A 10W30 at 200F would have losses about 50% lower (half of what is shown)
The SR20 max oil flow rate is less than 10 gpm, but just to give you an idea of why I was suggesting -10 over -8; look at the pressure loss for the two sizes at 10 gpm
sorry bout the large pic here.
Yahnozha is offline
Old 11-07-2005, 01:48 PM   #11 (permalink)
SE-R GREEK
I was just about to post about this but P@t beat me to it...
THis has been the major reason for not fiddling with oil coolers ever since Steven went through his cooler escursion and documented it in this forum...
hpro123 is offline
Old 11-07-2005, 03:11 PM   #12 (permalink)
John
John, this kit is for the highport motors, havent pieced together anything for a lowport.
Serban is offline
Old 12-03-2005, 05:40 AM   #13 (permalink)
engine #4 and counting
Trader Rating: 15 (100%)
Yeah, so with a stock de pump where does this put us at idle as far as psi?
Thanks,Jon
93 electric blue nx2000 with lots o mods.
91 g20 5spd dd soon to have t25 set up
99 maxima se 5spd: I/H/E
06 suzuki ltz 400 w/mods
cardomain.com/id/insaneimport2000
insane imports is offline
Old 12-03-2005, 05:44 AM   #14 (permalink)
Well acording to the graph i would be at 1 psi or so at idle, no thanks. Lets see some more info from some roadracers on this subject. Also do you have to saw or chop the long neck on our oil filter housing to use this?
thanks,Jon
Old 03-01-2006, 03:34 AM   #15 (permalink)
GTi-R SR20DET B14
Trader Rating: 19 (100%)
Do you sell just the oil cooler itself? I already have a filter rellocation kit
Testing & Tuning SR20DET
gtswrx is offline
Old 03-01-2006, 11:40 AM   #16 (permalink)
Tryin' To Be Like You
Nice!!!
Originally Posted by Shawn B
Purple monkey Fritos elbow dishwasher cigarette can-opener!
Acorn lug-wrench carpet vibrator Gatorade?!?
i am about to make that my sig shawn if you will allow it?
hell i did it so if you want me to i can get rid of it but i thought it was hella funny
skeeter149 is offline
Old 03-01-2006, 03:19 PM   #17 (permalink)
Yes we can sell you the cooler seperetly. $64.99
Serban is offline
Old 03-20-2006, 12:21 AM   #18 (permalink)
Oops read the graph wrong. That is a nice kit, do you have any problems fitting an oil filter on the end?
Thanks,Jon
Old 03-31-2006, 06:17 PM   #19 (permalink)
does the sandwich plate have a thermal divertor? or does 100% of the flow go through the cooler all the time?
-dave
92 Sentra 1.6T
dave_f is offline
Old 03-31-2006, 06:42 PM   #20 (permalink)
The oil always flows through the cooler.
Serban is offline
HTML code is On
