i have a det block and i need a banjo fitting that i can hook up a t3 oil feed line to. can you put something together or if you have a fitting i can just screw into the banjo fitting hole on the block that would be great.
If you need just the banjo fitting, we should have something like that, as for the bolt, not quite sure what size it is you need. I would also need to know what size fitting you need for the feed on the turbo.
__________________ Serban - EEN President/Founding Father
