Im running a group buy on new FTF rail...which is now, thru some cool negotiations, Custom Steel has the exclusive on. That being said, it is now gonna become the Custom Steel fuel rail. It has developed from a strict FWD SR20 rail into a RWD SR20 and RWD KA24 fuel rail for top feed injectors.
Currently I have 4 rails with the FTF logo on them, the rest will have the Custom Steel logo on them.
Made with some of the best fuel rail stock on the planet, and machined to some redicilous tolerances, here are the highlights.
Comes with all hardware, including fittings and brackets for $95 plus shiping ($5 US, $9 International) This is a special one time price and we will need 10 people to get this group buy going.
FPR adapters for the stock and nismo fuel pressure regulators are available for an extra $15. These are seperate items and you will have to run hose to this, it is not an intgreal part of the rail. Fittings for the FPR adapter will include: -6an oring boss fitting, 5/16 (8mm) barbed hose fitting, and plug, you will use the existing FPR and hardware to mount the FPR to this adapter.
I am taking payments in full or 1/2 down deposits and the remainder before it ships out. Deadline for this group buy will be July 29th, 2005.
So what do I need to do? Simple, to get in on the group buy, simply chime in here and then you start the process by clicking on one of the following...and follow thru with the check out sequence. All major credit cards and paypal accepted.
To add on the adapter, just click on the link for the rail and click on the link for the FPR adapter, the second window that opens will have both items on there.
Rails will be started once 10 people have comitted and either put down a deposit or paid in full, or on July 29th, which ever comes first. From that point it will take about two weeks to get the rails in the mail.
If you have any questions, feel free to ask, ill answer them in a timely fashion. I am running this GB on several different forums to help attain the quantity required for this.
Best Regards,
P@
