I am doing a group buy for the 11lb Braille Auto Development battery with the aluminum mount kit in the picture. This is the easiest and cheapest way to save weight. This is an awesome battery and I drive with it every day in my Z. This battery retails for $175 and the mount kit retails for $69, which together is $244.
I need to get 10 people to do a group buy of $170 for the 11lb battery and aluminum light weight mount kit.
Here is some info: Braille Auto Development No-Weight Racing Battery
SKU: B14115
It is no secret that the lightest car retains the advantage in virtually any motorsports competition because the lightest car accelerates quicker, apexes faster, and stops shorter than its competition. That is why automotive enthusiasts continue to run the Braille B14115 No-Weight Battery in their vehicles.
Tipping the scales at a mere 11.5 lbs, this battery sheds 25 pounds or more off the front end of most vehicles. This results in a lower center of gravity and improved handling, especially when installed in conjunction with other proprietary lightweight parts engineered by Braille.
Not only is the Braille No-Weight Battery the only lightweight battery designed specifically for automotive use, but its also backed by Braille’s 1 year limited warranty. With all that, it’s no surprise that Braille batteries appear under the hoods of motorsports' top contenders.
Braille translates into Performance You Can Feel!
B14115 Specifications:
Size 5.80 x 3.32 x 5.88
Weight in lbs 11.5
Service Life 3-5 yrs
B14115 Cranking Amp Tests:
PCA 5 sec 904
PCA 10 sec 791
PCA 20 sec 698
HCA 585
CA 486
CCA 360
Here are the pics of the battery mounted in my car :
