Go Back   SR20 Forum > Classifieds > Group Buys
Old 03-06-2007, 01:36 AM   #41 (permalink)
98 SE
Those weren't pictures of the products he's made...those are similar to what he intends to make
Koni www.koni-na.com
www.nissanroadracing.com
Old 03-06-2007, 01:39 AM   #42 (permalink)
SouthPaw
SentraDragon's Avatar
Put me down for one pair for my B13 NX. Give me your paypal when you set a solid price.
SentraDragon is offline   Reply With Quote
Old 03-06-2007, 10:43 AM   #43 (permalink)
Trader Rating: 26 (100%)
i posted photos of a semi finished prouct, on the bottom of the second page.
92 B13 ser:Black sr20VE
95 4Runner:Black
79 Ford f-150: Brown-wheelin machine
stephenjk13 is offline   Reply With Quote
Old 03-06-2007, 11:01 AM   #44 (permalink)
www.FAIRTAX.org
paNX2K&SE-R's Avatar
Trader Rating: 84 (100%)
Ummmm there are only 3 posts in the 2nd page so far...
02 G20 Sport 5spd
94 Miata "homobile"
93 240SX Family Project
Government run health care = fail
Old 03-06-2007, 11:03 AM   #45 (permalink)
merely a flesh wound
chriscar's Avatar
Trader Rating: 109 (100%)
User can set the page size to be longer than the default, so saying it's at the bottom of page 2 isn't going to work for everyone. I'm set to 40 posts per page.
1994 SE-R / SR20VE / N1 Cams / B15 trans / Calum Realtime / Hyperco - AGX / 15x7 RPF-1
1995 Turbo Miata R Package / GT2560R turbo / Megasquirt / Tein Flex / 15x8 949 6UL
Old 03-06-2007, 11:48 AM   #46 (permalink)
Originally Posted by stephenjk13 View Post
there is a lot of info. on the forum about what there for and what they help improve. but basicaly they help stiffen the front end of the car which will help imrprove handling
http://i29.photobucket.com/albums/c2...tephens061.jpg
http://i29.photobucket.com/albums/c2...tephens060.jpg
What is the front bolted to? That section of the frame is boxed in, so I don't think you could get a nut on the other side to bolt these down. Did you use Nutserts?
1993 NX2000 - D2s., ES Bushings, SSAC header, Hotshot CAI, VRS Exhaust, lots o' chassis braces.
1999 Infiniti G20T BB SR20DET
FMIC, Blitz BOV, 3" Exhaust, JIC SA-1 Coilovers. GTi-R manifold/T28, 3" DP, 3000 lbs. of entry-level luxury
SE-R_Dan is offline   Reply With Quote
Old 03-06-2007, 12:06 PM   #47 (permalink)
no i copied the idea of some that i seen on a 240, the are 5/16 screws.
95 4Runner:Black
Old 03-06-2007, 01:18 PM   #48 (permalink)
What do they screw into? I don't think sheetmetal screws through the frame rail would provide much chassis stiffening. You should look into Nutserts.
There's a nice animation showing how they work here: http://www.avdel.textron.com/index.h.../thin_sert.htm
I'm not dissing your effort here. I just want to make sure we get the best possible product. I think you'll also need to add a third tube to triangulate the prototypes in the pics you posted.
Old 03-06-2007, 01:25 PM   #49 (permalink)
[quote=SE-R_Dan;1866496]What do they screw into? I don't think sheetmetal screws through the frame rail would provide much chassis stiffening. You should look into Nutserts.
QUOTE]
well you dont have to buy them if you dont trust my idea, this is the best resort to using nutserts. the reasoning for going with screws is because with a screw you have a smaller whole and they are going into the core where it is overlapped so you will have plenty of strength
95 4Runner:Black
Old 03-06-2007, 02:00 PM   #50 (permalink)
SR 20 Site newbie
Does anybody know if the pulsar gtir is the same as the sentra ?.
I wouldn't mind a set of these for myself.
Rob
vpulsar is offline   Reply With Quote
Old 03-06-2007, 02:10 PM   #51 (permalink)
Awww.... Don't be like that. If you can't take a little feedback and a few new ideas then you're on the wrong forum. I hope you make an awesome product and sell a ton of 'em.
I just wanted to throw my concern out there that screws might not be the best option. If I wanted to use Nutserts or even weld these bars to the frame for that matter, I don't think you'd need to change your design. It should work either way.
Old 03-07-2007, 09:07 AM   #52 (permalink)
SE-R GREEK
Stephen, SE-R_DAN has made an extremely important and extremely valid point here.
It may work but it will be the 1st time that sheet-metal screws will have been used for (structural) chassis stiffening.
Old 03-07-2007, 10:01 AM   #53 (permalink)
Trader Rating: 48 (100%)
Originally Posted by NI SER-1 View Post
Just saw the photo's. Is that the finished prototype? What about the third piece that triangulates the brace?
that is a sound way of mounting the rear legs. triangulation isn't necessary as the door mounts are a solid structure tied into one another.
i would be more interested in what size/wall tubing you are planning on using.
the front mounts are an area of concern, as others have suggested
octotat is offline   Reply With Quote
Old 03-07-2007, 10:38 AM   #54 (permalink)
yes understand what you all are saying, but if you guys could purchase those nutserts and put them in.......the brackets are already predrilled so all you would have to do is mark the whole, drill, install the nutsert
95 4Runner:Black
Old 03-07-2007, 11:05 AM   #55 (permalink)
SR 20 Site newbie
I know its a bit of extra work, But couldn't you cut out a small piece of metal where the top mount will sit, And weld a new stronger bit in place with a captive nut attached.
That or drill a hole right though the metal both side's and weld a bolt tube in, Now that would be very strong and very easy to do.
Rob
Old 03-07-2007, 01:03 PM   #56 (permalink)
there are quite a few things that you can do in order to mount the front part of the brace, i just chose to send screws out with them becasue i dont thikn that everyone on her has access to a welder or has fabrication skills to weld a nut in.......
95 4Runner:Black
Old 03-07-2007, 01:14 PM   #57 (permalink)
Yeah, welding would make this more difficult. Is anyone a Nutsert expert who knows what we need and where to get it cheaply?
Stephen, do you know the thickness of the frame at the point where these braces bolt on?
Old 03-07-2007, 03:08 PM   #58 (permalink)
the core where the front bracket screws in is about an 1/8 to 3/16 thick...it is where the two pieces of the core overlapp and are spotwelded.
95 4Runner:Black
Old 03-07-2007, 07:56 PM   #59 (permalink)
Enjoying the Ride
happynole's Avatar
I am also ready to send money, but first want to get a resolution for the front mount. Sheet metal screws aren't going to be the answer, and I really only want to pull my fenders once. Anyone have a lead on the nutserts?
Ruby Red 91 NX2000.........I can't get Kimme out of the damn car
White 93 SE-R..................."no sir, it's just a Sentra"
Black 1995 G20t.................the perfect daily driver
Life is a Journey, Enjoy the Ride
SR20Deep(South)
http://www.datsun.org/roadster/liter.../dream_grg.mov
happynole is offline   Reply With Quote
Old 03-07-2007, 08:10 PM   #60 (permalink)
nutsert aren't going to be the answer - basicly a threaded rivet
Powered by vBadvanced CMPS v3.1.0
Powered by vBulletin® Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
