Btw: what are the exact specs on those Hawk pads of the big brake kit ?
The Hawk HP+ pads are an aggressive street pad that can take moderate track usage. From my understanding they dust alot, but that's to be expected from any type of pad like this.
The Hawk Blues that they mention are a track only pad that can not be used on the street... but they do great things on the track
what kind of clearance is needed for them to fit under some 15" rims?
There are a few threads that give a list of what fits, a simple search should help you there.
You could also go to Wilwoods website to get the dimensional drawing of the Dynalites, with this you can easily find the spoke clearance and inner wheel clearances that you'll need to know if they'll fit with current wheels that you have.
Thank Monty. If you are wondering what wheels these will fit under, PLEASE search before asking that question. Yes this is a group buy but be proactive and do some research in terms of what it will take to see if these will work in your application.
Many 15" wheels will fit and at the same time many will require spacers!
As for the thickness of the rotors, why do you need to know this? If you are buying the entire kit does it matter?
For the 11" kit the one piece and the 2 piece are the same thickness IIRC...
